Old 06-12-2018, 09:26 PM
Vansconvert Vansconvert is offline
Default Crimp or solder D sub pins?
Which is the way to go? I heard solder is better, and I heard crimping is better (easier for sure, but better?). Anyone know what places like SteinAir and Aerotronics are doing?
RV-7A
IO-360 Hartzell CSP
Purchased
Old 06-12-2018, 09:35 PM
merlin3 merlin3 is offline
Almost all shops will crimp i believe. I soldered when i installed my efis and havent had any issues but the last couple things i have installed/updated i have crimped.
Justin
Rv-6, o360, whirlwind cs prop, old paint and panel
Rv-4,o-320,prince prop, mgl avionics screens - sold
Old 06-12-2018, 09:43 PM
RV6_flyer's Avatar
Crimp. All the Aerospace giants use crimps for the following reasons.
Solder is NOT better. Takes more skilled worker, longer time, more steps, and if not done correctly, there are more failure modes.
Gary A. Sobek
NC25 RV-6
Flying
3,300+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 06-12-2018, 10:30 PM
az_gila's Avatar
az_gila az_gila is offline
And get the machined barrel crimp pins -
Not the cheaper stamped version -
They will be much easier to work with. Steinair has them.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 06-12-2018, 11:03 PM
If you don't have a background in electronics (meaning that you're very handy with a soldering iron), go with crimps for subD pins.
I've had several careers as an electronic tech. I've had a *lot* of practice using a soldering iron. I started out building harnesses using solder type subD connectors. I soon switched to crimps. I still solder a lot of stuff, but crimp subD's win for me for a number of reasons. They are much faster to assemble, they allow repositioning the pins (don't think you won't need this), and strain relief for individual pins is inherent in the connector body.
If you've never built the solder type subDs (and even if you have...), it's easy to destroy connectors due to overheating the plastic insulator material that separates & aligns the pins.
Hope that helps explain why crimps really are better, at least for subDs.
Charlie
Old 06-13-2018, 07:09 AM
Feetwet Feetwet is offline
Default solder or crimp rule
Some time ago I heard the following general rule:
Solder when corrosion is the main problem, crimp when vibrations is the problem.
Makes sense to me, I solder most boat stuff, crimp most airplane stuff!
Do use the machined pins and special crimper though, much better and easier in the long run.
Old 06-13-2018, 08:22 AM
rv6ejguy's Avatar
rv6ejguy rv6ejguy is offline
Default Another data point
We've soldered around 20,000 D sub connectors for our ECUs and other controllers (wire harness ends), some of these in service over 20 years and millions of hours in some severe environments. Zero failures.
If done right, extremely reliable.
Turbo Subaru EJ22, SDS EFI, Marcotte M-300, IVO, RV6A C-GVZX flying from CYBW since 2003- 427.8 hrs. on the Hobbs,
RV10 95% built- Sold 2016
http://sdsefi.com/cpi.htm
Old 06-13-2018, 08:37 AM
JonJay's Avatar
JonJay JonJay is offline
It’s now obvious to me. The only way is to “scrimp” them.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
Old 06-13-2018, 09:49 AM
rv6ejguy's Avatar
Both methods are reliable if done correctly. Use whichever one suits your skills, experience and equipment available.
Old 06-13-2018, 10:19 AM
Exactly.
My earlier post worked on the premise that if you need to ask, you probably don't have the skills, experience and equipment to get consistent good results. And there remains the issue of easily corrected wiring errors and easily modified harnesses, which can be a factor as avionics are updated/changed.
And to the vibration issue: That's an old hangar tale that just won't die. A crimped connection has exactly the same vulnerabilities as a soldered connection to vibration. Both require proper support outside the joint to avoid flexing fatigue failure at the joint. Yes, solder may wick up the wire. But proper support outside the joint protects the wire from flexing. Crimped joints have an even bigger vulnerability; there's a stress riser at the crimp itself and if not properly supported, that's where the wire will break.
Charlie
