Old 06-12-2018, 11:49 AM
Zazoos Zazoos is offline
Default WTB Case Mount Hardware for Plane Power Alt.
I purchased a Plane Power Alt from Vans with the boss mount. This was before I knew there was different mount types. My setup requires a Case Mount. If you have a case mount lying around let me know how much.
Thank you
Trent Flemming
Hallsville, TX
Purchased RV6 - Slider Project
Currently flying X-Air LSA and Powered Parachute
Dues Paid 10/2017
Old 06-12-2018, 12:54 PM
444TX 444TX is offline
I have several. One straight, one with a bend to move away from the block and one with two instead of three case mounting locations. Any one, $25.00, includes shipping. Can send pictures tonight.
George Meketa
Old 06-12-2018, 02:01 PM
bill@fusion4.net's Avatar
bill@fusion4.net bill@fusion4.net is offline
If that falls through for some reason I have one.
email me at bill@ fusion4.net (Remove spaces).
if need one.
Bill Thomasson
RV-10 - Flying - Phase II. 99.8% done... it's never really done!
http://sites.google.com/a/fusion4.net/rv10/
Suwanee, GA.
Old 06-12-2018, 02:15 PM
I should have mentioned the following.
Inside width of the case mount needs to be 3" with a 7/16 diameter bolt hole for the alternator. I prefer the 3 hole mount version. I only mention this as I actually have a case mount bracket that came with my engine that has a inside width of 3.75 inches and a bolt hole diameter of 5/16. I could rig it to work with the Plane Power alternator but would rather get the correct bracket.
George or Bill if you have the one I need it would be fantastic.
Trent Flemming
Hallsville, TX
Dues Paid 10/2017
