Old 06-11-2018, 11:00 AM
Bluelabel's Avatar
Bluelabel Bluelabel is offline
Default Cleaning AvGas stains?
Anyone got any good tricks?
I discovered a small leak at my wing root. I had filled up with cheap gas and flew the 4 minutes home. Some fuel dropped down along the bottom fairing and dried. Discovered it a week later during pre-flight, so it had obviously dried. So far,simple green down very little. Any other ideas?
John Walker
RV-10 N265WD
"Miss Whiskey Delta"
BPE IO-540, FULL EFII
KMYF, San Diego, Ca.
KEOS, Neosho, MO
Crew Lead on the
Grove Aero Super Legacy Reno Racer,
twin turbo, IO-540,
full EFII management system
"so I got that going for me... which is nice."
2017 Dues Paid"
Old 06-11-2018, 11:04 AM
xblueh2o xblueh2o is offline
More avgas.
Sam
RV-8 with the Showplanes Fastback conversion
Emp completed except for glass work
Wings completed except for bottom skin and glass work
Fuselage underway
N18451 reserved
Old 06-11-2018, 11:05 AM
moosepileit moosepileit is offline
Fresh avgas on clean white rag.
RV-6 N91GG, bought from builder.
O-320, slider, carb, mags, FP
Old 06-11-2018, 11:07 AM
sibriggs sibriggs is online now
Default use 100 ll
Best way to remove green stains is to use the 100 ll that caused them, take a rag and cup of 100ll and wet and rub, and wet and rub the stain over and over, it takes a while, but most of it will go away. Don't rub too hard or you'll dull the paint underneath.
Steve Briggs. RV9, G3x, G5, VPX, GTN625, A&P, IA, CFII
Old 06-11-2018, 11:49 AM
Bluelabel's Avatar
I think we have a consensus.
Thanks.
John Walker
RV-10 N265WD
KEOS, Neosho, MO
Crew Lead on the
twin turbo, IO-540,
2017 Dues Paid"
Old 06-11-2018, 12:51 PM
Mitch757 Mitch757 is offline
I used a product called “Goof Off” available from the local hardware store.
Mitch G.
Old 06-11-2018, 05:35 PM
GWZ GWZ is offline
I had a fuel stain on the leading edge of a white wing. Weather got hotter and fuel expanded and pushed out of the filler cap. I tried all the usual suggestions and none worked. Had a retired paint/body guy look at it and he even brought over a buffer and tried buffing it out. He declared it was “in the paint” and would need to be spot painted and blended. Well I put it on the “to do someday list”. After a few months the stain just faded away all on its own. Chalk up another win to procastion!
Gunther
2002 RV-9A 150hp
Old 06-14-2018, 12:53 AM
OKAV8r OKAV8r is offline
Start with 100LL, and then when that won't do anymore, use Hoppe's number nine
Old 06-14-2018, 07:31 AM
BCP Boys's Avatar
BCP Boys BCP Boys is online now
Use AVGas as everyone said, and then leave it alone. If you keep trying to get it out it will essentially dull your paint or even rub it off, depending how nice your paint job is. Even if it has stained the paint, it will get lighter as time passes.
Amir
RV-7 QB - N174WM
Supporting VAF since the first visit
