Old 06-10-2018, 07:41 PM
Jwputnam Jwputnam is offline
Default Oil cooler mount
I have searched the forum on the positioning of the FF-709 oil cooler bracket on the 705 baffle and have come up empty handed. I have a new IO-320 with vertical induction being installed with the recommended 360 cowl.
Can someone give me a recommended height for the FF-709? Someone must know this number. “As high as possible” is not a lot of help. It is so frustrating to be stopped cold when you have just so much time to get a section done. (Had to complain a little.)
RV-9A
Newbie
Dues Paid (and very thankful)
Old 06-10-2018, 09:00 PM
JohnInReno's Avatar
JohnInReno JohnInReno is offline
Default air flow
I have the same setup on my 9A.
ďAs high as possibleĒ means you want to picture the air flow through the cooler. If mounted too low, the #4 cylinder blocks much of the air flow.
I hope these pictures help:
John Morgensen
RV-9A N946PM 500+ hours since 2013
Nevada/Arizona
Old 06-11-2018, 04:57 AM
Interesting. Thank you. It looks as if the cooler gets pretty well blocked even as high as you have it, but it must work or Vans would not have designed it like this I would guess.
It appears that your installation barely raised it above the bottom of the 705, but any higher and you would have invaded the cowls space. I get it. I will mock it up on my engine this am and build on.
Thanks. Visuals sure help.
RV-9A
Newbie
Old 06-11-2018, 08:09 AM
RV9A Bill RV9A Bill is offline
Default Oil cooler mounting
Mounting the oil cooler on the firewall also works really well. I donít have a picture handy, but the firewall mount is very straightforward. Works great in my 9A.
RV9A Bill
RV9A Bill
RV9A 789BT flying
Old 07-03-2018, 09:10 PM
bweiss's Avatar
bweiss bweiss is offline
I have built 2 RVs a 7A and a 9 with on oil cooler mounted on the baffling and the other on the firewall. Even though I beefed up the baffle with doublets and angles I ended up with a crack by the first annual. I was able to stop drill and add more support but I was never happy. The second plane had a firewall mount and after 500 hours I am very happy. Obviously I recommend moving to the firewall
Bernie Weiss
St Paul MN
RV7A (sold)
RV9 flying - N579DB
Dues paid
