Old 06-10-2018, 06:05 AM
Reflex Reflex is offline
Default Elevator Horn/Bearing Question
Up to this point attaching the elevators to the stabilizer has gone very smoothly. Counter balances and trailing edges lined up, spacing at the counter balances is 1/8", drilling the hole in the horns went just as planned, and movement is very smooth. What could go wrong? !!
The problem I'm having is the space between the elevator horns and the main bearing is not enough to fit the required hardware between. In searching the form and multiple web sites, looks like most who've had an issue have had the opposite problem.
At issue is the spacing between the horn and the bearing is .0633 (about 1/16) and .033 (about 1/32). The space needed is .095 (about 3/32). Not sure how any of this can be moved or what I did wrong. Pictures below.
Ideas?
Dues Paid for 2018
RV-14
Empennage Complete
Getting Ready to Close Wings
Old 06-10-2018, 06:28 AM
Super Moderator
Default It's OK...
Assuming you can use a 5702 washer to fill the gap, just do that. You will be fine.
Vic
Vic Syracuse
Van's East Coast Representative
www.Baselegaviation.com
Old 06-11-2018, 12:13 AM
Av8rRob's Avatar
Av8rRob Av8rRob is offline
I had the exact same issue so dont feel bad.
Rob Lasater
Rv-14 emp/fuse done working on wings and finish
Paid dec 2017
Old 06-11-2018, 06:09 AM
Walt's Avatar
Walt Walt is offline
I've written about proper shiimming of the center bearing a few times over the years, bottom line: install whatever washers/shims are req'd to fill the gap completely so that when you tighten the center bolt it does not preload the hinge bearings!
EXP Aircraft Services LLC
RV7A built 2004, 1700+ hrs
Old 06-11-2018, 07:23 AM
Gents,
Many thanks. Relieved to hear it's as simple as using some additional 5702 washers. Didn't know if the NAS1149 washer was required for some reason.
Ordered some additional 5702-95-30 washers this AM.
Dues Paid for 2018
RV-14
Empennage Complete
Old 06-11-2018, 07:51 AM
JonJay's Avatar
JonJay JonJay is offline
You only need one 5702 on each side against the bearing. This large area washer keeps the bearing “intact” should it fail. You can use any thin washer/shim against it. More than one 5702 is just fine too but I thought you might want to know it’s purpose in case you didn’t.
You probably have a standard AN960L (thin) washer in your kit.
Keep on trucking!
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
