Old 06-06-2018, 11:09 AM
bkervaski's Avatar
Default Rudder Pedal Linkage
Are the rudder pedal linkage positions always symmetrical?
For example, the left linkage position seems to give slightly better rudder travel with equal slack on the opposite cable if I have it in a more aft position, one off from the opposite side.
Progress: First Flight Prep
Old 06-06-2018, 11:47 AM
sglynn's Avatar
sglynn sglynn is offline
Default Rudder links
Yes, mine are the same, at least to the tolerance I can detect.
I recently rigged my rudder cables and had the same question because I was prepared to cut the links different lengths. I spent too much time locking the rudder and pedals and measuring. Finally I figured if the cables are the same length and if you make all for of the little links the same length then the push on either pedal to move the rudder should be the same. So all my links are the same length.
Steve Lynn
RV-7A
90% Finished
Working on Wiring
Only panel left to go.
Anacortes, WA
www.mykitlog.com/sglynn
