Old 06-07-2018, 02:56 PM
DonFromTX's Avatar
I have, often on auto and tractor engines. The open valve face tends to pick up some oxidation, which allows for some leakage. I have never pulled a Rotax head but would suspect the same there. Try running a compression check on a Lycoming that has sat for a time, same effect. Compression comes up after even a short run.
Originally Posted by EXflyer View Post
Why would the valves not seat? Have never seen that on any auto engines that I have worked on.
Retired US Army Officer
Old 06-07-2018, 03:00 PM
DonFromTX's Avatar
You might be right there, had not thought about it much actually.
I think the reference was to lifter bodies pumping up with air if oil not purged correctly. You'd have to draw air into oil pump/pressure galleries.
Old 06-11-2018, 12:37 PM
rv7boy's Avatar
rv7boy rv7boy is offline
Forum Peruser
Jim, and others, you might be interested in reading this article on the Rainbow Aviation web site.
Don Hull
RV-7 Wings
KDCU Pryor Field
Pilots'n Paws Pilot
N79599/APRS Automatic Position Reporting System
ďCertainly, travel is more than the seeing of sights;
it is a change that goes on, deep and permanent, in the ideas of living." Miriam Beard
"It should be added that the sublime beauty of the facture brings within the realm of discourse the substructure of critical thinking. " -using Doug's Art Critique jargon link and my birthday, I get this!
