Old 06-05-2018, 06:38 AM
DaveO DaveO is offline
Default Height of fuselage
I am building a 14, I wish to build a variable height platform to sit the fuselage on.
My question is how high from the ground does the airplane sit when on the gear?
RV-7A N1243A Sold
#140479 RV-14A N1479B Reserved
Old 06-05-2018, 09:01 AM
control control is offline
I think it is 1.81m with the tail on, I will check fuselage only, later tonight. (Do note that you will need a lot more for operating the canopy)
RV-14 kit #140138
I have entered the 90% done, 90% left to do zone
Http://magnusrv.blogspot.se
Old 06-05-2018, 09:58 AM
Sneaked away into the shop before dinner
The cowling reaches about 171cm above ground and the spinner, front of the FW and even the roll over structure not that much lower...
RV-14 kit #140138
Old 06-05-2018, 01:09 PM
PatrickN PatrickN is offline
@control, Thanks for pointing out the open canopy height. I hadn't thought of that and wondering if it will fit in my garage. How high does yours open up? Mine should be the same as yours because we're both building tailwheel planes.
RV-14 #140469
Empennage Kit Complete - mostly
Working on Fuselage Kit.
Old 06-05-2018, 01:52 PM
Not sure,
When I did my canopy I had my fuselage on a really low table, about 30 cm above the floor. After mounting the gear and wheels I had to take my RV outside to open and remove the canopy.
My canopy is now in my bedroom and will stay there until it is time to move everything to the airport.
RV-14 kit #140138
Old 06-05-2018, 07:16 PM
Thanks guys for your help, but I did not explain myself fully.
Here is the height I need:
From the ground to the bottom of the fuselage adjacent to the gear leg. Not the nose wheel.
Thanks again, I hope I did better.
RV-7A N1243A Sold
Old 06-06-2018, 06:18 AM
MED MED is offline
I measure about 28 1/4" to the bottom of the fuselage at the gear leg.
MED
140236
N435MD reserved
Old 06-06-2018, 08:12 AM
Thanks soooo much for your help.
RV-7A N1243A Sold
