Old 06-04-2018, 03:50 PM
Zazoos Zazoos is offline
Default Fuel Pump Port Question
I purchased my low time 0320 back in Oct 2018 and even though I helped pull the engine off the plane after demonstration flight I have forgotten a few things.
I numbered the 3 ports on on the output side of the fuel pump. Does this seem correct.
My guess is:
1. To the carb. (however, very restrictive port)
2. To the transducer.
3. Overflow
Trent Flemming
Hallsville, TX
Purchased RV6 - Slider Project
Currently flying X-Air LSA and Powered Parachute
Dues Paid 10/2017
Old 06-04-2018, 05:02 PM
az_gila's Avatar
az_gila az_gila is online now
Smile
3 is the overflow
2 is the fitting for a hose to the carb
1 is a restricted (probably) fitting for a smaller hose to a fuel pressure sender.
Out of sight behind the pump should be a threaded (not pipe thread) hole for the inlet fuel hose fitting.
This is the fitting needed for the inlet - note it uses an O-ring to seal -
If you are basing your guesses by the direction the fitting face - No problem, the rt angle fitting should have a stop nut against the pump, loosen this and rotate the fitting as needed.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Mel's Avatar
Mel Mel is offline
You have 1 & 2 reversed. The restricted fitting goes to the pressure gauge.
A&P/EAA Tech Counselor/Flight Advisor/Nat'l Test Pilot School
<rvmel(at)icloud.com>
North Texas (8TA5)
Legend Cub purchased 12/2017
FRIEND of the RV-1
Eagle's Nest Mentor
Old 06-05-2018, 01:32 PM
Does this look like the correct fuel pump inlet.
https://www.aircraftspruce.com/catal...tting00781.php
If so, is that an AN 6?
Thanks for the help.
Originally Posted by az_gila View Post
3 is the overflow
Trent Flemming
Hallsville, TX
Dues Paid 10/2017
Old 06-05-2018, 02:07 PM
Trent---#1 is for fuel pressure, #3 for pump overflow. IF you are using a flow transducer, like a flo scan or a cube, it goes between #2 and your carb.
Tom
Tom Swearengen, TS Flightlines LLC
Ridgeland, SC
www.tsflightlines.com
Old 06-05-2018, 02:16 PM
pazmanyflyer's Avatar
pazmanyflyer pazmanyflyer is offline
You can get them directly from Van's too.
http://vansaircraft.com/cgi-bin/stor...=pump-fittings
Carlos in Arizona
EAA Chapter 538 President, www.538.eaachapter.org
Wittman Tailwind W8 N53CH (built & sold)
Pazmany PL-1 N2029 (bought & sold)
RV7 - N537TC (reserved & building)
Emp, Wings & Fuse done - working on FWF
"The air is an extremely dangerous, jealous and exacting mistress. Once under the spell most lovers are faithful to the end, which is not always old age." - Winston Churchill
