Old 06-03-2018, 09:46 AM
Reflex Reflex is offline
Default Elevator Throws...Another Question...
Today in checking the throws on my left elevator, I've run into an issue. Like many others here, I'm not getting the down throw depicted in the manual.
In searching the forum, I've come across several potential solutions, but have seen several that could be considered questionable. With that in mind, I'm hoping that you might take a look at the issue below and educate me on the best course of action.
Issue: Left elevator has a throw of only 23.5˚ in the down position when against the rear stabilizer spar. A throw of 25˚ +0˚ -.5˚ is called out in the manual.
Data:
  • 1 5/8" Minimum distance between spar web and torque tube met (1 11/16")
  • Rod end bearings are precisely 13/16" from spar to center of hinge point
  • Electronic level has been "zeroed" before taking measurement
  • Control surface begins in trail with counterbalance arm flush at 0˚
Found this posted by Scott on another thread:
Adjusting the rod end (elevator hinge points) lengths to vary the amount of deflection relative to the elevator stops is not recommended.
Scott McDaniels
Hubbard, Oregon
Pictures below:
Dues Paid for 2018
RV-14
Working on Empennage
Old 06-03-2018, 01:39 PM
Av8rRob's Avatar
Av8rRob Av8rRob is offline
My rodends had to be backed out a turn or two to prevent rubbing of the elevator leading edge to a rivet on the hs spar. Then when is movement was completely free I had no issues with range of motion
Rob Lasater
Rv-14 emp/fuse done working on wings and finish
Paid dec 2017
Old 06-03-2018, 06:41 PM
Tom023 Tom023 is offline
Check the Control Delections Letter on the Vans website. Down limits are between 20 and 25, so you are right in the middle of acceptable range.
RV14A #140083
Wings, empennage, fuselage and finish slow builds completed
FWF and avionics in progress
2017 Donation
Old 06-03-2018, 11:08 PM
Bob Kuykendall's Avatar
Bob Kuykendall Bob Kuykendall is offline
Originally Posted by Reflex View Post
...A throw of 25˚ +0˚ -.5˚ is called out in the manual...
I'm pretty sure nothing in the Vans world except wing twist (or lack thereof) is specified down to the fractional degree. As suggested Tom023, I suspect that that's -5˚, not -.5˚.
--Bob K.
Bob Kuykendall
HP-24 kit sailplane
EAA Technical Counselor
