Old 06-02-2018, 03:04 PM
bkervaski's Avatar
Yep, I simply flipped the sensor wiring, all fixed!
Thanks, all!!!
Progress: Away for PAINT
Old 06-02-2018, 04:30 PM
Erimo's Avatar
Erimo Erimo is offline
Yeah ! the big day is coming
I look forward to reach this step.
Congrats.
Eric
RV 14A - #140252 - close to flight.
France
2018 dues paid
Old 06-02-2018, 05:18 PM
azflyer21 azflyer21 is offline
Originally Posted by Tom Martin View Post
Use Pat Hatch's idea about using a heat gun to trouble shoot your sensor wires.
Try to keep engine starts to the bare minimum. First start to confirm oil pressure and that sensors are working, one minute or so.
Your engine came with a manual and it has information regarding the proper break in of a engine.
The main importance is as few starts as absolutely necessary and definitely no taxi tests!!
Can you please expand on this? Why does the engine only require a few starts and no taxi test?
Kevin Lippert
Zenith 750 completed 2016 -
Sold
N902X reserved
RV-14a Empennage Done
QB Wing QB Fuse inprogress
Build Log
Old 06-02-2018, 05:49 PM
Davoakes@att.net Davoakes@att.net is offline
Smile
I'll share why no taxi tests. I was advised that during a hight speed taxi test, you could find yourself flying before you are ready. In that case you may not be prepared for flight and may end up bad.
When I first took off for the first time, I was ready and I was told that my wheels were off the ground in 3 seconds. Not much time.
It does not take much effort to fly these creatures.
Daveoakes
RV-7A N1243A Sold
#140479 RV-14A N1479B Reserved
Old 06-02-2018, 06:39 PM
n982sx n982sx is offline
I would make that, no high speed taxi tests.
Think about it, if something were to not feel right you're just going to pull the power and stop. If not, your going to let it fly. So the high speed taxi test is just accomplished on your take off roll. Be prepared to pull the power if it gets squirrelly.
You can, and should still taxi some small amount to set the brakes and make sure all is working.
Bob Meyers
Built and Flying RV-14A N626KM SN 140093 http://n626km.com
Built and Flying Sonex N982SX http://n982sx.com
Old 06-03-2018, 03:57 AM
By using the new engine at low power settings you risk not getting the piston rings to seat properly. This could result in excessive oil consumption, reduced power etc.
I know how exciting it is to fire up that new engine but please follow the breaking procedures that come with the engine. Our airplanes are not “new” designs. We know that the Van’s airplanes taxi well etc.
Hire a known expert local small airplane mechanic to check out your aircraft and be there for first start. After 25 years and 11 airplanes they always find something, and that IS a good thing.
CPL & IFR rated
EVO F1 Rocket 1000 hours,
RV14 Tail dragger flying #153
Fairlea Field
fairleafield@gmail.com
