Old 06-01-2018, 03:12 PM
bkervaski's Avatar
Default First Start!
First start today, woohoo!
Fairly uneventful except there was an odd CHT/EGT issue on #3.
In the first 10-15 seconds the CHT shot up to 1000 degrees then a big red X appeared.
The EGT never went above 400 #3.
All the others leveled right out as expected.
The physical temps by touch were about the same for #3 as the others, didn't have a temp gun with me.
If it was just one of the sensors I would think just a bad sensor/wiring problem but both is throwing me off.
Does anyone have any suggestions or ideas before I start troubleshooting?
Not very helpful but here's a pic after I shut it down and was cooling, the sensor recovered, didn't think to take a pic while it was running.
Progress: First Flight Prep
Old 06-01-2018, 04:09 PM
JonJay's Avatar
JonJay JonJay is offline
Yay!! Big day.
Sounds like the CHT and EGT are swapped in the harness.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
Old 06-01-2018, 04:11 PM
Congrats Bill!----youre almost ready!
Tom
Tom Swearengen, TS Flightlines LLC
Ridgeland, SC
www.tsflightlines.com
Old 06-01-2018, 05:07 PM
scard's Avatar
scard scard is offline
That is super! You sure showed up and got with it. Congrats.
Scott Card
RV-9A N4822C flying 1900+hrs. / Cedar Park, TX
Track
Old 06-01-2018, 06:47 PM
Pat Hatch's Avatar
Pat Hatch Pat Hatch is offline
Good show!
Take your heat gun to each of the 8 sensors to make sure they correspond with the proper EIS indicators, thus confirming that they are all wired correctly.
Pat Hatch
RV-4 (Gone to RV heaven)
RV-6 (N44PH - Flying)
RV-7 (Sold)
RV-8 (Helped build Bob Lund's airplane)
www.phaviation.com Trim Relay Boards/Flap Actuators
www.pathatch.com/blog (Photography)
Track Me
Old 06-01-2018, 07:59 PM
n982sx n982sx is offline
It's real easy to get a wiring error in those 16 wires. I had an - off by one error - in my harness from Stein. Easy to do, Josh unknowingly skipped a pin in the connector after the first five. A couple of temps were correct in mine and then the rest were all screwy.
As another noted, appears that the a pair of EGT and CHT wires got swapped.
Bob Meyers
Built and Flying RV-14A N626KM SN 140093 http://n626km.com
Built and Flying Sonex N982SX http://n982sx.com
Old 06-01-2018, 11:37 PM
control control is offline
Cool!
I estimate that I am about 3 months in trail
RV-14 kit #140138
working on FW forward and finish kit
wings, tail kit and fuselage basically done
Http://magnusrv.blogspot.se
Old 06-02-2018, 08:55 AM
rapid_ascent rapid_ascent is offline
Pat,
That is a great idea for pre first start too.
Ray Tonks
2018 Donation Paid
RV-7 Fuselage in progress
* Fwd Fuselage Complete
* Mid Fuselage Complete
* Aft Fuselage Complete
RV-7 SB Wings
* Both Wings fully skinned
* Fuel Tanks Complete - No leaks finally
* Ailerons Complete
* Flaps Complete
RV-7 Empennage - Complete (a little fiberglass work left)
Vans Training Kit # 2 - Complete
Shop Setup - In Progress (Gathering Tools, Never Complete)
RV-7 Preview Plans
Vans Training Kit #1 - Complete
EAA Sheet Metal Class - Complete
Old 06-02-2018, 09:51 AM
Jesse's Avatar
Jesse Jesse is offline
I had the same thing happen. It makes it tough to troubleshoot unless you know how the connector is supposed to look.
352-427-0285
jesse@saintaviation.com
Old 06-02-2018, 10:13 AM
Use Pat Hatch's idea about using a heat gun to trouble shoot your sensor wires.
Try to keep engine starts to the bare minimum. First start to confirm oil pressure and that sensors are working, one minute or so.
Your engine came with a manual and it has information regarding the proper break in of a engine.
The main importance is as few starts as absolutely necessary and definitely no taxi tests!!
CPL & IFR rated
EVO F1 Rocket 1000 hours,
RV14 Tail dragger flying #153
Fairlea Field
fairleafield@gmail.com
