Old 06-01-2018, 02:31 PM
egp8111 egp8111 is offline
Default Ground Canopy retainer
With the coming of warm weather I quickly discovered I needed to install some method of holding the canopy slightly open on the ground. After researching the various methods guys have posted on the forum, this is what I came up with:
I'm sure someone else has done this but I couldn't find any pictures. Works well, just rotate the bar in when you close the canopy.( Top screw is short with a nut that catches the instrument panel lip to keep the bar from rotating any further out.)
Only took about 30 minutes to do and should work on any 4 with the plans built canopy lock. You might have to play with some washers to get your spacing right.
Skip
#1904
Old 06-01-2018, 02:41 PM
Default canopy closed
Old 06-01-2018, 05:42 PM
BruceMe's Avatar
BruceMe BruceMe is offline
I had something similar, under high revs on grass it popped off the pin and slammed the canopy open and broke the hinge.
YMMV
Bruce Meacham
Built/Own RV-4 254MM
Owned RV-6 4074V
First RV RV-3 3456B
VAF annual donation on autopay
Old 06-02-2018, 01:26 PM
Thanks for the heads up, I'll keep an eye on it.
Old 06-02-2018, 05:27 PM
Jvon811's Avatar
Jvon811 Jvon811 is offline
I've been looking for something similar to this... Is the canopy supported only on the front pin? What about the rear pin? If not the rear, is that torquing on the whole assembly? I'm thinking canopy/fiberglass cracking.
-Justin
RV-4 N249P O-320, Warnke Prop, GRT Sport EX
