Old 05-27-2018, 09:38 AM
JDA_BTR JDA_BTR is offline
Default Prop Clocking
About to install the prop and read all the related threads. Any reason to not clock the prop at 9-3 position relative to #1 TDC?
N1463 seems a good number....
Old 05-27-2018, 09:45 AM
jabarr jabarr is offline
The prop can only be installed 2 ways. They are 180 degrees apart. Look at the bushing lengths and recesses in prop hub.
Nova RV Nova RV is offline
Remember to align the crankcase split with the TDC marking on the BACK of the "flywheel", not the mark on the front. As far at 9-3 clocking I think it's another primer wars type issue.
Chris Moon
Leesburg, VA
RV-14A kit # 140243
VAF 2017 and 2018 paid
www.mykitlog.com/chrismoon/
Old 05-27-2018, 10:27 AM
Ok I'll look at the flywheel. On the front of the flywheel one hole is marked "O" and it is lined up with a similar "O" on the crankshaft flange. It is the way it was shipped. I'm assuming that is the correct alignment?
Old 05-27-2018, 10:31 AM
Mel's Avatar
Mel Mel is offline
Never assume anything! Do as Chris says, but make sure that #1 cylinder is at TDC.
A&P/EAA Tech Counselor/Flight Advisor/Nat'l Test Pilot School
<rvmel(at)icloud.com>
North Texas (8TA5)
Legend Cub purchased 12/2017
FRIEND of the RV-1
Eagle's Nest Mentor
Old 05-27-2018, 01:25 PM
Larry DeCamp's Avatar
Larry DeCamp Larry DeCamp is offline
Default Beware !
Some extensions are such that you cannot achieve prop alignment with the crank/rods at TDC. The reason is the prop bolts cannot align with crankflange bolts due to space constraints. Mine are 30* OFF. Just FYI, YMMV
Larry DeCamp
RV-3B flying w/ carb & Pmags
RV-4 fastback w/ Superior EXP 0360 /AFP & CPI
Clinton, IN
Old 05-27-2018, 03:53 PM
Are we talking all props need to be clocked correctly? My instructions for my 3 blade Catto didn't say anything about clocking it in any particular place. This may be another thing a non AP builder would not know.
rockwoodrv9a
Meridian Idaho
rockwoodrv9a@gmail.com
O-320 D2A
Awaiting DAR Inspection
Old 05-27-2018, 04:18 PM
As above there are only two possible fittings. The flywheel bushing at 0 mark is not protruding and so is the bushing 180 from it. The prop mount has 5 recessed spaces and only one bolt without a recess. So the bolt without the recess has to be at the 0 or 180 from it. So the prop clocking is fixed in the big picture. Im going to put the bolt with no recess with the 0 hole. It is the only different hole on the flange marking wise so Im going to match the marked/different items.
Old 05-27-2018, 04:24 PM
Mel's Avatar
Mel Mel is offline
This may be true with your engine and prop. It is not true on all engines and all props.
North Texas (8TA5)
FRIEND of the RV-1
Eagle's Nest Mentor
Old 05-27-2018, 05:11 PM
Agreed. Im using the Lycoming io390 thunderbolt specd for the 14 with the recc Hartzell c/s prop.
