Old 05-26-2018, 05:27 PM
klh1507 klh1507 is offline
Default Bottom skins
top skins are match drilled and J-stringers are drilled. Plans say do the same with the bottom skins.
Do I take the top skins off to put the bottom skins on or just struggle with lining up holes with the "screw on a broomstick" method mentioned in the plans?
Old 05-26-2018, 11:01 PM
bruceh's Avatar
bruceh bruceh is offline
I'm not sure I understand your question. You should be able to cleco all of the skins together in the proper layers and then match drill all of the holes prior to dimpling and riveting. Having the top and bottom skins on will help assure that you won't have any twist in the fuselage.
Bruce Hill
RV-9A N5771H flown over 600 hours!
2018 VAF donator
EAA Tech Counselor
Old 05-27-2018, 07:44 AM
I guess my question should have been "Should I take the top skins off before putting on the bottom skins?" It would be a lot easier without the top skins on but I was wondering about your point of the top skins keeping everything lined up. Thanks.
Old 05-27-2018, 09:27 AM
dwranda dwranda is offline
I'm not sure why you think it would be a lot easier to put the bottom skins on with the top skins off. If you are talking about moving the ribs slightly because the holes may not line up that's not an issue. Just start putting clekos from the top. You can always lift the skin up from the bottom and move the rib a little if you need to. Once you get a couple clekos in the top the rest should line up as you go along.
9A in progress
Working on Finish kit!!
Mattituck TMXIO-360 red gold
Dues paid Dec 18
Old 05-27-2018, 09:37 AM
Default My take
I would leave the top skins on when fitting the bottoms. If you did a good job fluting the ribs the holes will line up pretty close. If you follow the advice above and start from the spar to insert tbe clecos it will fit. I would also recommend you put the clecos in in some kind of pattern all the time. I found the skins were taunt without any oil canning if i inserted the clecos in a nice pattern. If I helter skelter it, i got oil canning and some misaligned holes in the left rear bottom spar area.
When you rivet, i would recommend you also follow a nice pattern to minimize oil canning. JMHO.
John S
Dues paid 2019, worth every penny
Fuselage 30%
Old 05-27-2018, 10:51 AM
az_gila's Avatar
az_gila az_gila is offline
Smile
Sounds like a job that can be helped with this low cost tool...
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 05-27-2018, 10:53 AM
+1 !!!!!!!
9A in progress
Dues paid Dec 18
Old 05-28-2018, 06:58 PM
Default Thanks, all.
guess I needed a little encouragement to remind myself that I can do this.
Old 05-28-2018, 07:11 PM
Don't sweat it. We all need encouragement at some point. I look at a lot of helpful build sites. It helps to visualize the steps that sometimes seem hard to understand. So many have come before us that we don't have to reinvent the wheel.
9A in progress
Dues paid Dec 18
Old 05-29-2018, 08:48 AM
airguy's Avatar
airguy airguy is offline
I remember a similar point in my build where I was frustrated with something, can't remember what. I finally just started grabbing tools and said to myself "It's either going to work, or I'm going to start replacing parts." Turns out it worked just fine.
Greg Niehues - PPSEL, IFR, Repairman Cert.
Garden City, TX VAF 2019 dues paid
N16GN flying 380hrs and counting! Built an off-plan 9A with too much fuel and too much HP. Should drop dead any minute now.
