Old 05-26-2018, 01:12 AM
wfinnell wfinnell is offline
Default Tail weight while hanging engine
Hi Guys,
How much weight do I need to add to the tail of the aircraft to hang the engine? I don't have the empinage or wings on yet.
Bill Finnell
RV-8 Fuselage
Tucson AZ
Old 05-26-2018, 01:23 AM
Robin8er Robin8er is offline
You dont need much, probably 30 pounds towards the tailwheel. I put some small paint cans and some junk I had laying around in the back.
You really dont need any, but it is pretty neutrally balanced with the tail and canopy off. As long as you add some weight you will be good. You will need more weight if you have the fuselage leveled.
RV-8
N695RA Reserved
Emp and Wings done, working on Fuselage.
Born to fly, forced to work
Old 05-26-2018, 03:53 AM
goatflieg's Avatar
Good to know. I'll be hanging mine soon and was wondering the same thing.
Martin J Filiatrault
Clarkston, MI
N657AR reserved
Builder websites:
YouTube Channel:
Dues paid for 2019... extra payment included for psychological therapeutic services rendered.
_______________________
Old 05-26-2018, 11:08 AM
Default Thanks!
Thanks for the quick reply. You guys are great.
Bill Finnell
RV-8 Fuselage
Tucson AZ
Old 05-26-2018, 12:54 PM
wjb's Avatar
wjb wjb is offline
+1 for the info; I'm at the same point, too!
Bill Bencze
N430WB (reserved) RV-7 #74152, tip-up. Working the baffles
Log at: http://rv7.wbencze.com
Defeating gravity one rivet at a time
VAF 2019 donation happily made
Old 05-26-2018, 02:37 PM
skyking902001 skyking902001 is offline
I laid a bag of sand over the tail wheel stinger--worked great.
Steve Riffe
RV-8
N23SR
Dues paid to 11-21-19
www.mykitlog.com/skyking90200
Old 05-26-2018, 08:52 PM
MeAndMyToys MeAndMyToys is offline
Default Depends on the engine and prop
On my Rv-7 a 25 lb bag of shot is not quite enough without emp or wings. 50 lbs will do ok though. That is with IO-360 angle valve and Hartzell c/s prop. With the empanage on it is ok. Very light though so I left a 25 lb bag of shot back there until I put the wings on.
N17BJ
RV-7 Tip Up slow build
200HP IO-360-A1B
Hartzell CS
Working on wiring and Fw Fwd
Got my RV-7 tail kit for X-mas 2012
Guess the Wife's on board!!
Dues paid 2/26/2018
Old 05-27-2018, 12:45 AM
rv8ch rv8ch is offline
Default 2 ways
I've done it two ways:
  1. 20+ liter jug strapped to the little tailwheel sawhorse when I want the aircraft level
  2. a pair of old car batteries in the baggage area when I want the tailwheel down.
Without them, it would be on its nose, that's for sure!
Mickey Coggins
http://rv8.ch
Old 06-05-2018, 06:11 PM
Berchmans Berchmans is offline
Default Tail weight
With the empennage installed I found no additional weight was necessary to hang a YIO360M1B with Hartzell C/S prop.
Burke Wick
Flying RV 8
Anchorage, Alaska
VAF Dues Paid for 2019
Old 06-06-2018, 09:15 AM
Terry Lutz Terry Lutz is offline
Default Weight On The Tail
We used an old inner tube, cut it in thirds, took one piece and folded one end together and held it with a hose clamp, filled it with sand, then sealed the other end the same way with a hose clamp. Laid it on the tail spring, and it worked great. Works good, lasts a long time, still use it on other jobs.
Terry Lutz
RV-8 "Sweet Nancy Lynn"
www.notesfromcapejuby.com
