Old 05-25-2018, 07:24 AM
Brendan03801 Brendan03801 is offline
Default Rusty steps
Hey guys, I'm getting to close to installing my steps (WD-1233-L and WD-1233-R) and I noticed that they've gotten rather rusty! Bear in mind I bought the fuse kit nearly two years ago, before the disruption of having my building partner pass away. And I live in a salt air environment.
Do I need to replace them? They are $475 for the pair! Thinking instead of having them sandblasted and powdercoated.
Builder #120893
Empennage completed
Wing kit underway
N603NH reserved
Donated for 2016
http://www.mykitlog.com/Brendan03801
Old 05-25-2018, 07:31 AM
I think I'd be more concerned about salt air environment affecting aluminum and structural components.
You can always use a step-stool to get in/out of airplane... but structural
Hinckley, Ohio
EAA #499867
PPL/ASEL 1970 - Sport Pilot since 2004
RV-12 E-LSA #120058 AWC Jul 2012 - Bought Flying Oct 2015 with 48TT - Hobbs now 391
LSRM-A Certificate 2016
Special Thanks to EJ Trucks
Old 05-25-2018, 07:50 AM
I prime all the aluminum parts and keep "components" wrapped until ready for installation. And yes, you're right, the steps are not structural in the sense that if they break, the plane breaks.
Builder #120893
Empennage completed
Wing kit underway
N603NH reserved
Donated for 2016
Old 05-25-2018, 09:12 AM
Light surface rust of uncoated 4130 steel would be normal. As long as there is no pitting, it should be fine to blast them clean and powderer coat or paint.
Scott McDaniels
Hubbard, Oregon
Old 06-12-2018, 10:52 AM
JimMac JimMac is offline
I’ve used a liquid product called “EVAPO-RUST Super-Safe Rust Remover” to clean rust off of rusty tools and other items. You just let the parts soak in this stuff for a while and then just wash it off. Works great! If the rust is severe, it may take a 2nd soaking.
Jim McCarter
Madison, AL
RV-12 N864RV 90 hrs TT
Donation Made for 2018
Old 06-12-2018, 07:32 PM
Naval jelly works well to remove surface rust. Should be available at your local hardware store.
