Old 05-22-2018, 09:39 PM
Captain Cowboy Captain Cowboy is offline
Question RV 12 ELSA Dual Throttle On 912 ULS?
We built a 12 ELSA with a single throttle per specs, then after FAA Cert. modified it with a Vernier Throttle. We now have need for a second throttle to the left of the pilot using the left seat. Does anyone have info/pics/data/suggestions as how to put the second one on the a/c using both Bing Carbs and syncing both throttles and the linkages. Thanks in advanced for your ideas! Doug Robison, email is--MarkPSU13@aol.com
Old 05-23-2018, 12:32 AM
hufise hufise is offline
The most people have a left arm to handle the throttle
And it works
Daniel #120383 500hrs
Old 05-23-2018, 06:27 AM
rongawer's Avatar
rongawer rongawer is offline
Default Wait a second...
Two throttle controls for the same engine? Even if you could come up with a “rube goldberg” type spring & lever assembly, which throttle control would be the master? Disregarding any means that it could be implemented, the words “fraught with peril” come to mind..
I suppose you could use some sort of fly-by-wire rheostat and servo assembly, I’d have to give that some thought.
I rarely am the naysayer, but on this one, I ask you to reconsider.
There’s a reason the throttle is universally in the center, for access to both pilots.
Ron Gawer
- RV12, N975G, Phase 1 testing
- BE58, N1975G, stimulating the economy one flight at a time.
Old 05-23-2018, 08:24 AM
Super Moderator
Default Not recommended, but...
Sure it could be done, but I think you would be complicating a system that really needs to be tight in order to keep the carbs sync'd.
But, just in case you are asking due to a handicap, a way to do it would be to make a bracket behind the panel which would hold a tube with 3 (or 4) arms on it. This tube would be the width of the 2 cockpit throttle locations, and each of those throttles would attach to their respective arm on the tube. Then, another arm (or 2) would attach the cable (s) to the carbs. You would need one arm on the tube if using a dual cable, and 2 arms if using separate cables.
It would be really easy to fabricate, and not add much weight. I'm sure someone on this forum could 3 D print it for you.
Vic
Vic Syracuse
Van's East Coast Representative
www.Baselegaviation.com
Old 05-23-2018, 08:25 AM
EXflyer EXflyer is offline
Default Throttle
Thought way back when the RV6 came out there was some chatter about that. It would have been, well way back, before the internet. Yes there was a time that was true. Don't know but think there was a news letter back then for the three models they had. RV3,4 & 6.
Old 05-23-2018, 09:32 AM
I agree with Vic. This would be the only way I can think of to do it.
It is the basic concept that may of the Zenith airplanes have used over the years. They have a throttle on each side because they used a central control stick between the seats. You could find someone with one of those airplanes to see how they do it.
Scott McDaniels
Hubbard, Oregon
Old 05-23-2018, 09:51 AM
Mel's Avatar
Mel Mel is offline
I actually did this when I built a Zenair 601HDS except I used pushrods from the "bellcrank" (forward of the firewall) to the carbs because I don't like the cables. This also removes the springs that pull the throttle to wide open. Movement of the engine is very minor and is sideways in nature so having the pushrods running from the firewall to the engine work well. This aircraft now has over 1900 hrs on it with virtually no problems.
A&P/EAA Tech Counselor/Flight Advisor
<rvmel(at)icloud.com>
North Texas (8TA5)
Legend Cub purchased 12/2017
FRIEND of the RV-1
Eagle's Nest Mentor
Old 05-24-2018, 02:46 PM
Smile Dual throttles in RV 12 reply
Thanks to all who responded, I had a stroke 4 years ago and can fly from the right seat easily, I thought that someone else might be in need of the info as it is easier to view/interpret the D180 data siting in the left seat using the left stronger arm for power control. Thanks Mel for your info as I may use some of it if and when I decide to modify my 12. Again, thanks to all, your thoughts/ideas are much appreciated!!! Doug Robison 120254
