Old 05-22-2018, 07:39 PM
drtgraves drtgraves is offline
Default tail feathers build time
About how long is everyone spending "hands on" building the empennage? I'm trying to plan on when to order my wings with the 8 weeks lead time
Old 05-22-2018, 08:17 PM
Bgill Bgill is offline
Default Tail feathers build time
I took about 6 weeks - some others will be longer. I was planning on 8 weeks for the wings but after ordering, the lead time was ~12 wks. Mine are due to ship next week. Left me with 4 extra weeks to get all the fairings done...
You may want to call Vans and see what the current backlog is. The listing is not always correct.
Old 05-22-2018, 08:20 PM
so 50 hours? 100?
Old 05-22-2018, 08:59 PM
How much experience do you have in aluminum aircraft construction? That'll be the deciding factor. A new builder could easily spend 200 hours due to work pace, drilling out rivets, and going through the learning curve (on the aluminum and fiberglass). An experienced builder might be able to do it half the time.
Kyle Boatright
Atlanta, GA
2001 RV-6 N46KB
Old 05-22-2018, 09:30 PM
Davoakes@att.net Davoakes@att.net is offline
I am an experienced builder, 7A; but the Rv-14 is fast build kit. I am on the empennage and I have 104 hours, I have the VS, HS, Rudder and about 1/2 of the Elevators complete as of today. I received the kit on April 11, 2018. I think I am doing well. I have not worked on it every day, only today did I spend 7 hours.
I think I will order the rest of the plane, quick build, when I finish the elevators, which should be next week. Too much life getting in the way.
Daveoakes
RV-7A N1243A Sold
#140479 RV-14A N1479B Reserved
Old 05-22-2018, 11:03 PM
control control is offline
I spent 272.8 hours on the tail kit. Being an inexperienced first time builder. I could probably cut that in half if I were to redo it.
RV-14 kit #140138
working on FW forward and finish kit
wings, tail kit and fuselage basically done
Http://magnusrv.blogspot.se
Old 05-22-2018, 11:37 PM
Bavafa Bavafa is online now
It took me just about two months to finish the empennage and tail cone, this includes priming all parts and finishing the fiberglass parts (HS/VS caps)
Mehrdad
RV7A - IO360M1B - SOLD
Dues paid
Old 05-23-2018, 01:25 AM
RV7ForMe RV7ForMe is offline
Default This is a good question.
Took me a year to build the first kit (RV7). I took my sweet time. But I did not count the hours. Did not have to replace any parts. Everything is primed. Fiberglass is done.
Just stared on the Flaps and now I am counting hours. Looks to me like most build logs state 25-30 hours for both flaps. I will need more! Simple fact that it appears to take me 3 times the time to deburr all the parts as others are stating on their logs... Priming also takes me for ever!
VAF dues paid until 05/2018
RV7 - Empennage 95% done
RV7 - Wings Started...
Cessna Rocket 210HP - Best dang 172 Ever made! (sold)
Old 05-23-2018, 05:39 AM
mturnerb mturnerb is online now
As others have said, calendar time to build a section depends on how much time you have to build on a daily/weekly basis, experience level, whether you prime internal parts, overall attention to detail, amount of rework (I rebuilt an elevator for example - first one was probably fine, but I wanted better). You should be able to get a sense of your style and time to build after the first couple of sections, but sections aren't the same in terms of time. VS takes very little time, HS and elevators are more involved: sections with trailing edges (rudder, HS) and rolled edges (rudder, elevators) take some extra time that may include bonding trailing edges and forming leading rolled edges. Look at plans and take into consideration the number of parts and associated prep time etc.
Another factor to consider is not only wait time for the kit, but your distance from Van's and shipping method - if you're using Partain you may want to consider their schedule. Also - if you have room to store wing kit while still building the tail it might make sense to order sooner to avoid any risk of interruption (wish I had done this with fuselage which I did after tail).
Turner Billingsley
RV-14A In Progress
N14TK Reserved
Old 05-23-2018, 07:31 AM
azflyer21 azflyer21 is offline
Just finished my empennage and it took 185.0 hours of actual build time. This includes the many hours reading, re-reading and interpreting the plans.
Kevin Lippert
Zenith 750 completed 2016 -
Sold
N902X reserved
RV-14a Empennage Done
QB Wing QB Fuse inprogress
Build Log
