Old 05-21-2018, 05:40 PM
jpflys1 jpflys1 is offline
Default Rudder trim tab
Should the trim tab be installed, or wait for flight to see if needed?
I am thinking paint the part, rivets and not drill holes now.
Old 05-21-2018, 08:13 PM
All of the RV-12's I have worked on needed one and for the majority that it gets installed on, the preset angle perfect.
Scott McDaniels
Hubbard, Oregon
Old 05-21-2018, 09:01 PM
DHeal DHeal is offline
The pre-bent tab I received from Van's was perfect right out of the box for my rudder trim needs. When you install the tab, sneak up on the pull-rivets located near the rudder's trailing edge -- there isn't a lot of clearance there for the rivet's shank until you give it a bit of a squeeze and ease the rivet into final pull position.
RV-12 E-LSA #120496 (SV w/ AP and ADS-B) - N124DH flying since March 2014 - 670+ hours (as of Sept 2018)!
VAF donation through June 2019.
