Old 05-21-2018, 10:29 AM
ChuckC ChuckC is offline
Default Exhaust Spring Rubbing On Cowling Air Duct
The spring on the left front of the exhaust (just below the #2 cylinder) has been rubbing the cowling air duct. The rubbing has gone through the heat shield and is now working on the fiberglass. The air duct is dimpled to make room for the spring; but, in my case, it looks like it could use another 1/8” to 3/16” of space to keep the spring and air duct from rubbing together. This is the original exhaust system on the 912ULS. This condition was found during the 200 hour engine maintenance (replace spark plugs, etc.).
I am thinking of cutting an oblong hole around the spring’s mark on the air duct and fiber glassing in a bubble to make more room for the spring.
Any suggestions?
Chuck Carlson
120445
Old 05-21-2018, 10:41 AM
JBPILOT JBPILOT is offline
Default At a quick glance - -
Looks like you could bend the spring connection loop closer to the exhaust and gain some clearance.
John Bender
Flying RV-12 - Serial #120036
Paid in May ( 5-4-18 )
Old 05-21-2018, 10:50 AM
alexe alexe is offline
Chuck,
Most of the builders I know of had to cut out and re-fiberglass the area in question. If I recall correctly, there were also clearance issues between the cowl and the valve cover of cylinder #2. Same solution there.
Alex
Alex Erdelyi
RV-12 #120758, N912AE
Flying as of 4/28/15
Paid through December, 2018
Old 05-21-2018, 11:28 AM
DHeal DHeal is offline
Yup, like Alex said.
RV-12 E-LSA #120496 (SV w/ AP and ADS-B) - N124DH flying since March 2014 - 640+ hours (as of June 2018)!
VAF donation through June 2019.
Old 05-21-2018, 01:02 PM
f1rocket's Avatar
f1rocket f1rocket is offline
I just seating the spring in some RTV on the cowl and monitored it. It never got worse in three years.
Randy Pflanzer
Martinsville, IN (II87)
www.pflanzer-aviation.com
Paid through 2043!
Lund fishing Boat, 2017, GONE FISHING
RV-12 - Completed 2014, Sold
427 Shelby Cobra - Completed 2012, Sold
F1 EVO - partially completed, Sold
F1 Rocket - Completed 2005, Sold
RV-7A - Partially completed, Sold
RV-6 - Completed 2000, Sold
Long-EZ - Completed 1987, Sold
Old 05-25-2018, 04:45 AM
BigJohn BigJohn is offline
No pictures showing up. Go with the fiberglass bubble and never worry about it again.
VAF paid through 10/2018. Best bargain in town.
Old 05-28-2018, 09:51 PM
DaveWelch DaveWelch is offline
Originally Posted by DaveWelch View Post
Ya know, that’s not a bad idea. Assuming Chuck is happy with his oil cooler to muffler clearance, temps are OK, and nothing else is clattering against the cowling...just patch over the area with a piece of new foil, add some high-temp RTV and fly on. No messing around with more fiberglass if you don’t have to.
On second thought, I'd recommend cutting it out and glassing in an area that gives you some clearance as you first mentioned and others have recommended also. That's what I did during the original build. Not that much trouble and gives you much piece of mind.
RV12 N951DZ
First Flight 9/23/16!
No paint yet. Working on a scheme with John Deere colors or accents.
Old 05-29-2018, 04:16 PM
Thank you all for your responses. Took the majority's vote and installed a bubble in the air duct. Now have a good 1/8" clearance all around the spring.
Chuck Carlson
120445
Old 05-29-2018, 04:20 PM
Alex, I also checked my cowling valve clearance on #2 and #4. #2 has at least 1/8" clearance; but, #4 is a little closer - but, still, not touching or rubbing on the cowling or coolant radiator.
Appreciate the help! Thanks!
Chuck Carlson
120445
