Old 05-18-2018, 12:00 PM
Default Stall Warning – 1 Vs. 2 Onboard…
I’ve noticed my stall warning is far less sensitive in the landing flair with only one person onboard with minimal fuel. In the above scenario the landing flair in ground effect is longer and it takes a very pronounced nose-high full-stall landing to get the stall warning to annunciate.
With a second person onboard and ¾ fuel the stall warning annunciates much sooner in the flair and nose of aircraft is not nearly so high an angle.
I have checked stall warning vane geometry and switch setup against drawing 16-03 and everything looks correct.
So, I’m wondering if others are seeing this same thing…
Hinckley, Ohio
EAA #499867
RV-12 E-LSA #120058 AWC Jul 2012 - Bought Flying Oct 2015 with 48TT - Hobbs now 406
LSRM-A Certificate 2016
Special Thanks to EJ Trucks
Old 05-18-2018, 04:40 PM
rmartingt's Avatar
rmartingt rmartingt is online now
Assuming you're flying the same speeds... I'd think that would be expected, with significantly more weight on the aircraft.
RV-7ER - canoe flipped
There are two kinds of fool in the world. The first says "this is old, and therefore good"; the second says "this is new, and therefore better".
Old 05-18-2018, 06:12 PM
Sam Buchanan's Avatar
been here awhile
Sounds like it is working very nicely!
The aircraft is going to stall at more nose-high attitude (slower airspeed) at light weight than when flown with a heavy load. The AOA is doing just what it is supposed to do, telling you what the wing is seeing.
I've been flying AOA in my RV-6 for over 15 years and consider it the primary instrument for landing. Study AOA and understand what it is telling you and it will be a valuable resource.
Sam Buchanan
1999 RV-6
1918 Fokker D.VII replica
Old 05-19-2018, 09:34 PM
Mine stopped working —- can’t say I miss it!😜
Old 05-19-2018, 10:43 PM
Hmmm... I'm ready to be (re)educated. Everything I've ever read said that an a/c in any single configuration always stalls at the same AOA, and only the stall airspeed varies.
Old 05-19-2018, 11:28 PM
I'm with you Charlie.
Joe Gores
RV-12 Flying
Old 05-19-2018, 11:47 PM
Me two (also too).
I do think there is the possibility that pilots of light aircraft flare into zero sink rate, while when the airplane is heavy they pull up to the same attitude as light -but that’s insufficient to completely check the descent. Due to the descent the angle of attack is higher than it appears.
Old 05-20-2018, 01:48 PM
sblack sblack is offline
Stall attitude will always be the same but it will happen at lower speed at lighter weight. If you approach at the same speed irrespective of weight you will spend more time in the flare bleeding off the excess speed so you might get to a higher attitude. If you want your approaches to be consistent then fly slower when you are lighter. Multiply your heavy weight approach speed by the square root of the weight ratio i.e (actual weight/max weight). So if you are 10% lighter than full fuel and 2 people, approach 5% slower and it should feel pretty much the same. You would be flying a constant V/Vstall ratio, which is how most larger high performance airplanes are operated.
Scott Black
RV 4, with an engine...and other stuff
VAF dues 2018
