Old 05-22-2018, 12:44 PM
Scott, I never did test the difference between the "0" setting and the -3 or reflex setting. I can understand how it would climb a bit better in the "0" but what is the actual climb difference in feet per minute?
The climb is so good in the reflex position, even at gross weight that I wonder it is worth the bother. There is also the opportunity to forget to go to reflux at cruise, not that I ever forget to flip a switch....
CPL & IFR rated
EVO F1 Rocket 1000 hours,
RV14 Tail dragger flying #153
Fairlea Field
fairleafield@gmail.com
Old 05-22-2018, 01:13 PM
I can't remember the amount of difference testing showed.
Perhaps Steve (airfoil designer and RV-8 owner here on VAF) would comment on what the theoretical difference is.
Scott McDaniels
Hubbard, Oregon
Old 05-22-2018, 01:14 PM
I have actually wondered about the opposite question: Is there a density altitude, above which true airspeed is higher with zero deg flaps? I did some experimenting around 16,000 DA (iirc) and couldnít detect any difference. But it wasnít perfectly smooth at the time.
A scond question for Scott: my 2009 rv10 kit came with a max speed limitation for zero flaps. Has that been removed from newer kits? Do I need any upgraded parts to remove the limitation?
Old 05-23-2018, 06:56 AM
n982sx n982sx is offline
Originally Posted by bkervaski View Post
I'd love to know what your -3 and 0 voltages are set to in the calibration.
Here they are.
Bob Meyers
Built and Flying RV-14A N626KM SN 140093 http://n626km.com
Built and Flying Sonex N982SX http://n982sx.com
Old 05-23-2018, 09:17 AM
Bavafa Bavafa is offline
Originally Posted by n982sx View Post
Here they are.
Can't view it and I would like to know how this is setup as it won't be long before I need to do this.
Mehrdad
RV7A - IO360M1B - SOLD
Dues paid
Old 05-23-2018, 09:28 AM
Nothing has changed
That is why in my description of how we operate the airplanes I mentioned that we climb at the zero flap setting, cruise and descend at the -3 setting, and then revert back to zero when slowing for pattern entry.
Scott McDaniels
Hubbard, Oregon
Old 05-23-2018, 11:02 AM
KeithB KeithB is online now
My understanding (and I could be completely wrong), is that reflex helps take some load and trim off the tail, particularly with lighter loading = forward CG. With higher and aft loading, it is less beneficial. In certain circumstances, I have seen a 3 knot improvement at cruise going from trail to reflex position on flaps. In other circumstances, Iíve seen negligible effect.
Like others have posted, I use trail for takeoff and climb, and during maneuvers such as instrument approaches - otherwise reflex.
Keith Brown
RV-14A Builder - kit #136
N314KC - First flight Mar 8, 2017, >300 hrs
RV-6A sold
Sport Pilot (weight-shift control) - Airborne XT912
Dues paid 11/2017
Old 05-23-2018, 12:37 PM
bkervaski's Avatar
@n982sx Thank you! It appears your voltages are scaled opposite mine. I looked online at some other screenshots of the calibration screen and they line up with yours. So, it appears, I may have two wires swapped on the POS-12.
Progress: Away for PAINT
Old 05-23-2018, 12:51 PM
No.
It is like I already said, its specific to the airfoil design and a reduction in induced drag.
Otherwise it would be beneficial to all the RV's, regardless of what model.
Scott McDaniels
Hubbard, Oregon
Old 05-23-2018, 09:52 PM
I should have mentioned that I swapped the wires from the sensor to reverse the slope of the voltage line. I also had to swap the the GAD 27 flap wire control wires.
The GAD 27 software seems to think that the signal voltage will always drop as the flaps come down. This is not true with the installation of the POS 12 per Vans RV 14 installation. This is really a software problem fixed via hardware. Nothing wrong with the Van's installation or the POS 12.
Bob Meyers
