Old 05-17-2018, 01:26 PM
Djgeib Djgeib is online now
Default Perplexed?
Iím working on my -8 QB fuselage. Drilled the holes for the mid cabin covers and am putting in the nut plates. However, the aft most hole on the right side has put me in a quandary. I have removed the console cover but the angle that it attaches to is preventing me from being able to get a squeezer or my rivet gun in to lay flat on the rivets. Was wondering how others have done this. I have clearance on all the other holes. Iím sure there is a simple solution that has evaded me. Thanks
https://douglasgeib.smugmug.com/N104MG/i-Ds5B4fZ
Doug Geib
KFHB
RV8 empennage complete
QB wings started
Old 05-17-2018, 02:08 PM
N729LS's Avatar
N729LS N729LS is offline
Just nutplate, no? The nutplate attach rivets are not structural Use countersunk 3/32 pop-type rivet.
Andy
Andy Elliott, CFI, RV-8, N303RV
Flight Reviews, Dynamic Prop Balancing
KFFZ, Mesa, AZ
Old 05-17-2018, 02:34 PM
cdeerinck's Avatar
cdeerinck cdeerinck is offline
Default Use the gun
Use a rivet gun and bucking bar.
I don't think you can do the entire plane with just a squeezer.
~Chuck
DG-800S Sailplane
QB RV-8 -- Working on the canopy and wiring
84CX Reserved
Old 05-17-2018, 06:33 PM
sjhurlbut sjhurlbut is offline
Default Couple options
I use clickbond nutplates for locations like this but if want this nutplate I would drill holes to #33 and pop rivet MSP32 rivet on both sides.
For these nutplates that hold panels like this I also recommend tapping the nutplate before riveting it. They can be very tight to get screws in later.
"Aerodynamics is for people who can't build engines"
Enzo Ferrari
Steve H
Cold Lake, Alberta
RV7A #70015 - C-FZQX - built - sold
RV7A #71629 - C-FSIS - built - sold across Atlantic
RV7 #70215 - C-GOJU - flying - sold
RV7 #70703 - C-GMIY - flying - sold
RV6 #60119 - C-FHBZ - built - Airventure 2016 Bronze Lindy - sold
RV10 #41779 - built emp - sold
RV8 #82842 - C-FSBG - Fastback with big hp IO-360-A1B6 10:1
Old 05-17-2018, 07:57 PM
Thanks for the replies. Iíll do it with pop rivets. I knew it would be a simple solution but sometimes when youíre trying to fit rivet guns and squeezers in tight places, frustration gets the best of you and you canít think clearly. Thatís why I get on this forum daily. Itís the best resource out there!
Doug Geib
KFHB
QB wings started
Old 05-17-2018, 08:48 PM
xblueh2o xblueh2o is offline
Parallel jaw pliers are your friend. They will squeeze -3 easily and -4 if you have a gorilla grip. If I am doing just a few rivets I will just use these instead of dragging out and adjusting a squeezer.
Sam
RV-8 with the Showplanes Fastback conversion
Emp completed except for glass work
Wings completed except for bottom skin and glass work
Fuselage underway
N18451 reserved
Old 05-17-2018, 08:50 PM
BoilermakerRV's Avatar
BoilermakerRV BoilermakerRV is offline
Question Click Bonds
Originally Posted by sjhurlbut View Post
I use clickbond nutplates for locations like this...
Enzo,
Where do you get your click bonds from?
Michael
Danville, IN
RV-7A Fuselage
N317PU Reserved
2018 Dues paid (August 2018)
Old 05-18-2018, 02:06 PM
nilberg nilberg is offline
Thatís a good idea. You can even drill holes in the jaws to hold dies for dimpling.
Bjorn N - RV 7 in progress
Katy, TX
http://www.mykitlog.com/N741BN
Old 05-18-2018, 03:07 PM
cdeerinck's Avatar
Default Click bond
Originally Posted by BoilermakerRV View Post
Enzo,
https://www.electricalhub.com/click-...SAAEgIo-PD_BwE
~Chuck
DG-800S Sailplane
84CX Reserved
Old 05-18-2018, 04:34 PM
goatflieg's Avatar
I remember what a bear these were. Van's instructions recommend using vice grips modified with flat jaws... and just squeeze the heck out of them. I was less than impressed with my own results... but after a bit of touch-up they were adequate rivets for securing nut plates. This is one of those jobs that had me dreaming of inventing the perfect tool for the job...
Martin J Filiatrault
Clarkston, MI
N657AR reserved
Builder websites:
YouTube Channel:
Dues paid for 2019... extra payment included for psychological therapeutic services rendered.
_______________________
