  #161
Old 05-19-2018, 11:10 AM
joedallas's Avatar
joedallas joedallas is offline
Default My View
Scott
I made it perfectly clear that this is not a recommendation.
We have different views on what a patch looks like.
I can install vinyl over LP4 Rivets and with a lot of finger time they look ok.
I think it looks better over CS4 Rivets.
And Vinyl over a Patch Still Looks Like A Patch in my view.
We also designed a lot of things before Computers were invented.
I sure if you ran a computer analysis on my design it would stack up pretty well with Van's and a lot better than Vans original design, and with only few problems worked pretty well.
However that is not the point, I am building EAB so I can have the Aircraft I want not a standard RV12 which is a well built Aircraft.
It is a good thing that Van used his own ideas to built all the great Aircraft in his line.
Thanks for your View
The full sized doubler was not designed specifically to a repair stabilators that were found to have cracks.
It was specifically designed based on doing an FEA (finite element analysis using a computer model), and analyzing the loads seen in the hinge joint / fwd spar.
My recommendation to other builders is that they install the parts as designed.
There will be no problem applying vinyl over the doubler (if that is your plan) after some experience is gained working with the wrap material.
Joe Dallas
Kit-#12400
www.joesrv12.com
www.EAA1298.com
Old 05-19-2018, 01:07 PM
Not a patch. Patches are for bicycle tires. Aircraft don't do "patches". Correct term is doubler. Look at the bottom of your fuselage and you will see a number of doubler plates in high stress locations. Doublers are used to distribute load safely into the surrounding skin...
Hinckley, Ohio
PPL/ASEL 1970 Sport Pilot since 2004
RV-12 E-LSA #120058 AWC Jul 2012 - Bought Flying Oct 2015 with 48TT - Hobbs now 350
LSRM-A Certificate 2016
Special Thanks to EJ Trucks
Old 05-19-2018, 01:59 PM
joedallas's Avatar
Default This is Silly
http://hhh.gavilan.edu/hspenner/iLea...uralRepair.pdf
See page 140
The doubler is not a patch there in no damage under it.
It is just a term
My View It is a Patch
Joe Dallas
Kit-#12400
www.joesrv12.com
www.EAA1298.com
Old 05-19-2018, 02:06 PM
I doubt if I'd do a "wikiHow" even (with pictures) for aircraft repair, but maybe some people would...
Hinckley, Ohio
