Old 02-01-2018, 05:30 AM
ppakotze ppakotze is offline
Originally Posted by BobTurner View Post
Since com transmissions (unlike VOR) use vertical polarization, you also should have mounted it as high (or low) on the rib as possible; and then bent it (close to the rib) down (or up) as much as possible.
Thanks for the heads-up Bob. I was trying to get the antenna further away from the cockpit due to the EFIS screen radiating interference. From experience with antennas on small metal structures instead of on the ideal flat metal ground plane I have found that the polarisation is not as clear cut as one would think.
Nevertheless not flying yet, so will experiment and see how it works. My thinking was that it could always be used for VOR/LOC later on (currently no nav radios). Valtronics makes a remote mount Nav receiver which could always be installed later and driven from the EFIS.
Regards
P.
Old 06-04-2018, 09:22 AM
Rbb469 Rbb469 is offline
Originally Posted by Sam Buchanan View Post
http://www.aircraftspruce.com/catalo...clickkey=29765
Notes from when I installed the Archer antenna in my RV-6 many years ago. It still works great.
Thank you very much for your detailed write up. Iím ordering my BA antenna. Thanks again, Ricky
Dues gladly paid!
Old 06-04-2018, 10:55 PM
jpowell13 jpowell13 is offline
Default Which radio?
Jacksel, I'm curious about which VOR radio you're using. I have Bob Archer antennas in my wingtips. They barely worked with my VAL Nav2000, but work great with the VAL INS429 I installed later. John
