Old 06-17-2017, 08:15 PM
rongawer's Avatar
rongawer rongawer is offline
Originally Posted by Tony_T View Post
Yes, but it is a $30,000 panel.
Not really. The reality is that all in, including all switches, wiring, connectors, electrical system, relays, antennas, control sticks, and avionics, it was $23,000. Compare that to the Vans avionics kit with electrical parts and it's not much more.
It took a lot of homework, bargain shopping and do-it myself effort though.
Ron Gawer
- RV10, N1530G (reserved). Empennage in progress.
- RV12, N975G, Flying
Old 06-17-2017, 08:22 PM
rongawer's Avatar
Originally Posted by hthaman View Post
Amazing panel, can u fly IFR ?
Yes, I can. That was the main plan for me to be able to do my daily commute to work. I tend to have about 70 approaches a year with the marine layer on the coast and wanted to have the best situational awareness and setup I could in our little hummingbird.
Joe, thanks. It's coming along.
Ron Gawer
Old 06-18-2017, 01:49 PM
pstraub's Avatar
pstraub pstraub is offline
Wow...impressive Ron, congrats!! I remember all those times back in the '80s where I couldn't get home to PAO because of the marine layer. I was stuck shooting an approach into SJC and waiting until about noon so I could get a SVFR clearance to PAO. I love the fact that they have an approach now and you can take advantage of it in your -12!!
Paul Straub, First Flight May 5, 2017
N917PB, SN 120971
120 hours and counting.....
Old 06-18-2017, 02:08 PM
tomkk's Avatar
tomkk tomkk is offline
Isn't power for all that marginal with just the engine generator? Or are you adding an aux generator?
Also, are you leaving the pitot where it was? I'm thinking about pitot heat ...
Tom
Port Orange, Fl
RV-12 N121TK ELSA #120845; first flight 06/10/2015
RV-12 N918EN ELSA #120995 Eagles Nest Project; ready for engine & avionics
Old 06-18-2017, 06:00 PM
Dvalcik's Avatar
Dvalcik Dvalcik is offline
Nice panel
How much room do you have with the Canopy frame? My panel is close and just barely fits. How thick is the bezel on the Garmin?
Look at the upper left corner of the GRT on the pilot's side - not much room.
David
EAA 1434 KBST
Belfast, ME
david@rv12pilot.com
2018 VAF Supporter
RV12 #568 EAB
* Started 9/30/2011
* 1st flight 8/30/12
http://www.rv12pilot.com
Old 06-18-2017, 07:01 PM
rongawer's Avatar
Thanks Paul. It'll be nice for those "gentleman IFR" days. I don't have any plans to launch off into the clag for a hard IFR flight though, but it would be possible. Can't wait until we can go flying together.
I have a Garmin heated pitot with AOA that is mounted out in the left wing (...where God intended ). I have a 50A permanent magnet alternator that should do well. My computed loads are about 39A, but that's with everything on, the aux power outlet with a 5A load and full pitot heat. Pitot heat drops off pretty quick after you turn it on as the probe heats up. I expect full electrical loads around 30A, or less, in normal flight.
Originally Posted by Dvalcik View Post
Nice panel
Thank you!
I don't have my canopy done yet, but I did install the frame to test this as I was installing to be sure about clearance. Unless something changes dimensionally with the canopy attachment, it should be ok.
With the frame mounted
About 1/4" gap
Ron Gawer
Old 06-18-2017, 07:25 PM
Dvalcik's Avatar
Ron looks good - I see the VPX - I put one in also. Your going to have a nice bird.
David
EAA 1434 KBST
Belfast, ME
david@rv12pilot.com
2018 VAF Supporter
RV12 #568 EAB
* Started 9/30/2011
Old 06-18-2017, 08:01 PM
rongawer's Avatar
Hey, good eyes! And thanks...lot's of "stuff" left to go.
Ron Gawer
Old 05-29-2018, 11:40 AM
rongawer's Avatar
Default Here's an updated
I'm going to be moving my airplane to the airport in a couple weeks, but it's essentially done.
This is my panel with the canopy open:
https://office365stanford-my.sharepo...JISww?e=avnehx
And this is it closed:
https://office365stanford-my.sharepo...UXMIg?e=kLKYHH
I meant to add that once I finished up, I found I had to remove a little material at the upper outboard corners of each display to prevent any contact with the canopy bar. It would open and close, but rubbed. Rather than trim the bar (allowed in the drawings), I decided milling off a little plastic easy. I meant to go back and put some black paint on the corners, but just realized when I saw the picture online that I forgot that. Anyway, I had a "I have made fire" kind of moment when I turned it on and it all actually works, including all of the engine telemetry. Now, on to the actual engine noises...
Ron Gawer
