Old 02-08-2015, 03:57 PM
Maxrate Maxrate is offline
Default AVEO light discoloration
I have a 5 year old posistrobe XP that has pretty much set in the box. The polycarbonate material that the LED is encased in has disclolred, almost a yellowish brown, like the headlights of the late nineties. The light operates correctly however. Sorry no pics. Has anyone else run into this with the AVEO products. The supplier that I purchased from has moved on and Spruce can't offer any info.
Mark Malone, RV7
Wings complete, SB 14 complied with, fuselage in progress.
N442MM reserved
http://www.mykitlog.com/MikeMike
2017 Donation gladly paid.
Old 02-08-2015, 04:04 PM
RVDan RVDan is offline
I have their lights installed and had one fail. Contacted them directly and they made good. You might want to contact them to see what they say. The lights have a lifetime warranty.
Dan Morris
Frederick, MD
RV6 built and sold
N199EC RV6A flying
Learn the facts. "Democracy dies in darkness"
Old 02-08-2015, 04:24 PM
RV7A Flyer's Avatar
RV7A Flyer RV7A Flyer is offline
Yep, had the exact same problem on mine (although it was mounted a couple of years ago; airplane is hangared, so the amount of direct sunlight on it is theoretically about the same as the flight hours, 300 or so).
Aveo replaced it no problem just this week. They said they have improved their polycarbonate housing since the product was first introduced (my Aveo Ultra Embedded nav/strobe lights show no discoloration).
Contact them directly...PM me for email of the guy who helped me. VERY responsive customer service from their Florida office.
Old 02-08-2015, 08:57 PM
gyoung's Avatar
gyoung gyoung is offline
Guess it depends who you talk to. I had nav/strobes installed for ~500 hrs when I called to complain about them being discolored and rough. The guy I talked to told me to clean them with denatured alcohol and buff them out. If they didn't clean up to call them back. I quizzed him about the material since they're using the same advertising term, Diatanium or something, as when I purchased. He said they changed but seemed to waffle whether I had the old or new. They cleaned up to be more presentable but still not as clear as when new. I haven't called them back but the conversation left a real bad taste.
Greg
1950 Navion - flying
RV-6 - 15 yrs and 96.3% done
3.5 L-2 projects on deck
Old 02-09-2015, 07:56 AM
wm708 wm708 is offline
Default the good the bad and the ugly
Polycarbonate
Has some good and bad properties.
It's very bendable and very safe because it's very soft, drills very easy.
Great for impact resistance and safety wear.
On poly sheets it will say this side out because it has a UV coat added on that side.
On eye wear UV coat is added automatically. Not the best optically, also has chromatic distortions
Will Yellow over time.
Bill
Old 02-09-2015, 05:38 PM
GalinHdz's Avatar
GalinHdz GalinHdz is offline
I had the same experience with my AVEO POWERBURST Nav/Strobe lights and my airplane is always hangared. They told me they have to be buffed and waxed once or twice a month and it is specified in section #8 of the POWERBURST Installation Manual. They did send me some kind of "buffing compound" that helped a bit but did not clear up the yellowish haze. As a comparison my KUNTLEMAN beacon, which is 3yrs older than the AVEO, is as clear as the day I bought it and I have never buffed or waxed it.
I haven't called them back but if the lights fail or get too opaque I will change to another brand.
Galin
CP-ASEL-AMEL-IR
FCC Radiotelephone (PG) with Radar Endorsement
www.PuertoRicoFlyer.com
Old 02-09-2015, 09:17 PM
agirard7a's Avatar
agirard7a agirard7a is offline
Default Aveo
Oh well. Was planning on buying these as well
As a tear drop shaped landing light that I was planning on
mounting to the inspection panel. I now have second thoughts.
Al Girard, Newport, RI
N339AG
RV-9
Old 02-09-2015, 09:22 PM
bkthomps bkthomps is offline
Aveo CEO has yet to write me back about a product inquiry, this combined with the constant promises of the Conforma wing tips and then misdelivery, has me doubting the company, especially with the prices they command
EDIT: I did hear from someone else at Aveo, who was extremely helpful- perhaps the CEO is busy, which is understandable. I was rather eager to display the Conforma wingtips and exchanged 15-20 emails inquiring about fit and details, I still do not have a pair nor have been offered the opportunity to purchase a pair, so i'll leave that comment in place
Brian
RV7 - Finishing, Who knows, make me an offer
Lancair Super ES-TN - G3X Touch/GTN
RV4 - Skyview Sold!
Old 02-10-2015, 04:47 AM
catmandu's Avatar
catmandu catmandu is offline
Guess it depends who you talk to. I had nav/strobes installed for ~500 hrs when I called to complain about them being discolored and rough. The guy I talked to told me to clean them with denatured alcohol and buff them out. . . . They cleaned up to be more presentable but still not as clear as when new. I haven't called them back but the conversation left a real bad taste.
Identical to my experience, although only my port light is the problem child.
Mike C.
Maryland's Eastern Shore
stuck in 1/5th of an Arrow, my partners won't let me go
RV-6A bought flying
Old 02-10-2015, 01:56 PM
Christian Gather Christian Gather is offline
I'm not sure who told you this but feel free to call me at 631-327-2632 should you need anything.
