Old 05-28-2018, 05:38 PM
JDA_BTR JDA_BTR is offline
Default Spinner Fitting
Just did the trial fit of my spinner. Then roughed and put epoxy on the inside of the spinner.
The prop is protected with the bags and tape it was shipped in and not very thick but not thin either. Iíve sanded the spinner back to just at the outside of the trim line. It seems the prop is very close under the tape to the edge of the spinner.
Also it seems that the back of the spinner is 1/8 or so aft of the bulkhead plate. I donít think that creates a problem?
Last is the diameter at the rear spinner is a little bigger than the bulkhead plate and doesnít fit exactly.
I think I will have to take the bags off and put one tape layer down to really see whatís up. How has the Vanís spinner marking worked out for others?
N1463 seems a good number....
Old 05-29-2018, 10:28 AM
Logan Logan is offline
Some of the later step will have you trim the openings around the prop blades to give a certain (1/8"?) clearance, and you trim the aft edge to be flush with the read spinner bulkhead later, as well. When you do the clearance, I did push the factory plastic up the blade a bit and put thin tape on the prop blade to help a little for protection.
Logan Dent
RV-14A Complete!
Airworthiness cert issued June 27, 2018
