Old 05-27-2018, 07:18 PM
JDA_BTR JDA_BTR is offline
Am I reading the Hartzell install torque table correctly? I think for the four AN4H-4A bolts to the S-603 front spinner bulkhead the torque should be 20-22 ft-lbs but it isn’t explicitly called out like it is for the hub clamping bolts to the spinner plate assembly.
Ser 104142, RV-14A
N1463
Final Assembly....
Old 09-08-2018, 04:42 PM
Bavafa Bavafa is offline
Originally Posted by JDA_BTR View Post
Am I reading the Hartzell install torque table correctly? I think for the four AN4H-4A bolts to the S-603 front spinner bulkhead the torque should be 20-22 ft-lbs but it isnít explicitly called out like it is for the hub clamping bolts to the spinner plate assembly.
I believe the 20-22 ft-lbs is the value for the AN5 bolts that hold the spinner back plate. I would imagine the AN4 bolts for the front plate would take the standard torque value but please let us know if I am incorrect on this.
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - Phase one
Dues paid
Old 09-08-2018, 05:42 PM
Tom023 Tom023 is online now
I installed my prop today and that is how I read it. For the AN5 bolts I also found some variability in the amount of torque to tighten each which I added to the 20 ft/lbs.
RV14A #140083
Down to last 5%.
2017 Donation
