Old 05-21-2018, 02:54 AM
control control is offline
Default G3X-GEA24-eMag from Lycoming/Vans
Hi,
So any experiences from using the tach signal from the emag directly to the GEA24, works good?, without or with a resistor and if so, value?
(Getting my GDU470 this afternoon and will order a GEA24 very soon, wondering if I need a separate RPM sensor)
RV-14 kit #140138
I have entered the 90% done, 90% left to do zone
Http://magnusrv.blogspot.se
Old 05-21-2018, 06:51 AM
Christer's Avatar
Christer Christer is offline
The P-Mag RPM output from pin 6 of the P-Mag can go directly to the RPM input on the GEA24 without a resistor. I have a similar setup on my RV-8 but I have a GSU73 instead of the GEA24 and it works perfect.
Christer
Avionics Manager, SteinAir Inc.
RV-8 Completed
Old 05-21-2018, 07:24 AM
Jared_Solomon's Avatar
Jared_Solomon Jared_Solomon is offline
Thumbs up Same setup in mine
I have my Emag RPM output wire directly to me GEA. Works perfect.
Jared Solomon
A&P, EAA Technical Counselor
Powder Springs, GA
2018 Dues Paid
RV-14A (N214WJ) - Flying since Sept 2017
RV-7A (N211WJ) Flying since 2009 (SOLD)
RV-7A (N132RD) bought flying 2014 (SOLD)
KPUJ (Silver Comet Field)
Youtube channel: http://www.youtube.com/jmsolomon2000
RV-14 Build Log: http://rv14.jaredsolomon.net
Old 05-21-2018, 11:38 AM
Perfect, exactly the answer I was looking for, thanx!
btw Christer, the 470 and 625 I ordered from you have now arrived in Sweden after the short stop in Houston TX
RV-14 kit #140138
Old 05-21-2018, 01:37 PM
Bavafa Bavafa is offline
The avionics shop that I am purchasing my avionics from ask me if I am going with PMAG or Slick as there is a difference in part number and the cost is about $100 more for PMAG. I did not ask what or why but apparently it does make a difference.
Now obviously folks who have responded here have hooked it up and is working fine so I guess that is the surest assurance that it works.
Mehrdad
RV7A - IO360M1B - SOLD
Dues paid
Old 05-21-2018, 06:28 PM
czechsix's Avatar
czechsix czechsix is offline
I would have thought it would be the other way around ($100 more for the Slick interface)...with the Slick you're buying an extra sensor that picks up the tach signal, whereas with the PMag you're just interfacing directly to it with no additional sensor to purchase.
Mark Navratil
Spring Hill, KS
RV-8A N2D #80583 - built/flew/sold
RV-14A #140017 - wings complete, empacone in progress...
