Old 05-15-2018, 03:33 PM
Stockmanreef Stockmanreef is offline
Default Wiring ELT connector
I prefer to not screw this up. On the WH-00125 wiring diagram for the Tailcone Left it shows the wiring of the 4 pin connector for the ACK-ELT (RS-232 DIN connector).
So here is the stupid question:
It shows the pin diagram but not which side one is looking at. Am I looking at the side with the pins you solder on to? Or the plug side (finished end).
I did look up the pin diagram on Mouser and that shows it from the front of the plug, so the pins are in the back.
thanks
ken
Ken Stockman
Midland, MI
EAA Chapter 1093 member
RV-14 (serial number 140073)
N73XP (at least that # reserved now)
Old 05-15-2018, 04:54 PM
az_gila's Avatar
az_gila az_gila is online now
Question
Does page 8 of this help?
http://www.ackavionics.com/wp-conten...INGLE_PAGE.pdf
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 05-15-2018, 06:36 PM
Yeah, I looked at that before i posted and the bottom right of the page shows the labeling end on (finished plug side) and the top shows the other side. I was just not sure that Van's labeled it the same way and that there a standard convention for labeling.
thanks
ken
Ken Stockman
Midland, MI
Old 05-15-2018, 07:59 PM
az_gila's Avatar
thanks
ken
The convention should be to use the pin numbers 1,2,3,4
If Vans used the pin numbers then both pictures on page 8 are correct, one looks from the solder cup side and one looks in from the contact side.
The pin numbers should define the connections.
Gil Alexander
