What are you guys using to the screw the rod end bearings into the elevator and rudders? I lubed the threads with Boelube and was able to hand tighten for a few turns. The location in the leading edge prevents using a wrench; however, I was able to get a 18mm socket to fit over the entire bearing end. The socket unfortunately really scraped up the plating on the bearing ends. I though about a crows foot but I do not own any. What am I missing on screwing these in without damaging them in the process?
