KRviator
When I built the -9A, I enabled the datalogging feature on the SkyView as well as installing a Navman MiVue 530 Dash-camera on the roll bar behind the Coey's seat. As most of my flights are solo, the view of the back of a head is fairly infrequent and it provides a video and data log of all my flights and actions in the event I spear in.
I downloaded the card the other day to grab some footage of my recent landings to measure the numbers and you can see the results for yourself. The -9A, admittedly one of the lighter ones out there, can consistently pull off ground rolls under 600' with moderate braking on a slightly uphill runway and is likely capable of sub-400' ground rolls for a maximum performance landing if need be. You can also have fun showing off to Diamond pilots at the holding point by crossing the threshold on a 3000' runway at 250' AGL and still make the turnoff at the far end.
The runway at Somersby is only 600m / 2000' long, 850'AMSL and on top of a plateau, slopes down 2* to the north and is surrounded by trees, so most FW landings tend to use Runway 17 and takeoff on 35, irrespective of the wind.
For those considering a -9A, enjoy!
https://youtu.be/VBPCMDG-YqI
