Update,
I was able to use my original front faring. I had to do things a bit different than the provided instructions.
(1) I riveted the new U-00006E-L-1 U-00006E-R-1 onto the new fork.
(2) drilled out the rivets and removed U-00006D-1 from both sides of my old faring.
(3) Do not remove the angle piece U-00006A-R-1 (right) or U-00006A-L-1 (left) from the faring. New ones are provided in the kit but I did not use them.
(4) Fit / clamp the new U-00006D-1 pieces onto the angle pieces in #3 above already part of the faring, None of the holes will line up, not the 3 mounting holes or any of the rivet holes.
(5) Be sure the rear faring will mount up to your front faring in this position. My front was narrower than it needed to be in it's relaxed state.
(6) Match drill the mounting and rivet holes from the new U-00006D-1 to the existing U-00006A-L-1 & U-00006A-R-1
(7) Rivet together using the new holes.
(8) This method was easier and took less time vs using a new front faring, not to mention I didn't have to match paint.
Disclaimer: This is the way I did it, I am not responsible for anyone else. Do this at your own risk.
