Old 01-11-2018, 08:31 AM
Default YD
Don't know if you are going Garmin but they reference this topic in the manual.
As you stated, the YD can contribute, but is not meant to be a trim tab...
Bob
Aerospace Engineer '88
Structure - 90% Done
Cabin Top - Aaarrghhh...
Doors - Done
On Gear
290 HP Barrett Hung
Dues Paid 2017,...Thanks DR+
Old 01-11-2018, 08:44 AM
Plummit's Avatar
Plummit Plummit is offline
My -10 has an electric trim tab and I have to adjust it several times on any given flight depending on the speed. So in climb, with 25 squared, I'll have it trimmed differently than in cruise, and that will be different that approach and landing. Yes I still use the rudders on T/O and in the pattern, but only for short periods. I cna't imagine a trim "tab" being very useful with the wide speed range of a -10.
-Marc
N814RV
2018 Donation made!
Old 01-11-2018, 08:49 AM
Auburntsts's Avatar
-Marc
You have to pick a specific flight regime, typically the one where you spend the most time. For most RVer's that have gone this route, it's cruise.
Todd Stovall
PP ASEL-IA
RV-10 N728TT - Flying!
WAR EAGLE!
Old 01-11-2018, 08:57 AM
9GT's Avatar
9GT 9GT is offline
I used a Ray Allen servo and a short piece of hinge to fab my rudder trim tab. I found it to be an invaluable item for trimming the aircraft out. The servo was mounted to the access panel to the left of the rod fairing. Its not clearly visible in the photo.
[IMG]DSC01477 by David C, on Flickr[/IMG]
David C.
Howell, MI
"Donor Exempt" but donated through Dec. 2018
Old 01-11-2018, 09:44 AM
brad walton brad walton is offline
If you add a servo inside the rudder, you may be changing its flutter speed. I have no rudder trim on my RV8. The need for trim and in which direction change with speed and whether you are in climb or descent. In cruise, mine requires light right rudder pressure. Without it, I'm a half ball out. I've found no difference in speed ball centered or a half ball out.
Old 01-11-2018, 02:46 PM
redbaron redbaron is offline
Smile Rudder trim tab
Todd, Just give van,s order dept. a call, It,s not listed.
Old 01-11-2018, 03:18 PM
”Everyone loves what they decided to do.”
Usually this quote is applied to avionics, but it applies here too.
Build the plane, fly it, then decide on rudder trim.
For the record, I went with a fixed wedge, ball centered in my typical cruise. Other cruise configurations might require a very slight rudder input - so small that once applied, friction holds it! Climb, I need to hold some right rudder, for sure. I have no intention of adding rudder trim. OTOH, adding aileron trim is on my wish list.
Old 01-11-2018, 03:25 PM
RV8JD's Avatar
RV8JD RV8JD is offline
Originally Posted by redbaron View Post
Vans has a nice rudder trip kit. nice and very low cost. give them a call
Originally Posted by Auburntsts View Post
Really? Is it listed on their website?
Must be this from "The List", for the RV-12, but probably adaptable:
12 RUDDER TRIM KIT, TRIM TAB & RIVETS, $7.00
Carl N.
Arlington, WA (KAWO)
RV-8, 290 Tach Hours
(Pic 1),(Pic 2)
(Pic)
Glasflügel H-201B Standard Libelle, N564NS - Sold
Rolladen-Schneider LS1-f, N61MP - No longer owned
