Old 01-07-2018, 10:56 PM
LordofWar LordofWar is offline
Question Go/No Go - Spar Caps Trimming
I started on my vanís RV-10 Empennage kit and in the first step of the Vertical Stabilizer, it calls for trimming the rear spar caps (Section 6, Page 2 - Step 1). I made the markings, drew a straight line and trimmed it. When I came back and read the plans again I realized I didnít straighten the bow while I drew the straight line.
https://imgur.com/a/lLnKD (First time posting a pic)
Attached is the picture of the rear spar cap clamped straight. I placed a piece of scrap aluminum with a straight edge against it to show the issue. Now the question is, is it acceptable to go forward?
Rajiv Chalasani
RV-6 - Red Phoenix (N111BN)
RV-10 - Tail Kit Started
2017 Dues Paid
Old 01-08-2018, 12:49 AM
RandyAB RandyAB is offline
I personally don't think that this would critically weaken the stiffener. Do any of the match drilled holes have less than minimum edge distance? It looks to me like you are fine. From your picture, the last #30 hole on the cut flange would be the one to check.
______________________
Randy P.
1st time builder
RV10 - Empennage (Started March 2017)
St. Albert, Alberta, Canada
2017 dues paid
Reserved:C-GRPY (GRumPY)
Old 01-08-2018, 01:53 AM
I only trimmed 16" from the end(Sharpie Mark). So the material near the last #30 hole is in the clear I believe.
Rajiv Chalasani
2017 Dues Paid
Old 01-08-2018, 10:00 AM
BrianDC's Avatar
BrianDC BrianDC is offline
Default Don't see an issue
Doesn't look like this is going to be a problem. I would build-on.
As always, I encourage you to call / e-mail VANS anytime you have questions. Advice from the internet is free, but not always correct!
Brian Lester
RV10 - #41778
Empennage - Done (for now)
Wings - in progress
RV10builder.com
PPL / IR - KVKX / KHEF
Old 01-08-2018, 11:40 AM
Yes. A call to Van's to double check is always a good plan.
Randy P.
1st time builder
2017 dues paid
Old 01-08-2018, 01:33 PM
Thank you Randy and Brian. Got a thumbs up from Van's to Build on.
Rajiv Chalasani
2017 Dues Paid
