Old 01-04-2018, 09:56 AM
Default bolts
I used four 3/8" hardware store bolts. I ground off the threads and tapered the ends slightly.
Worked good. I would NOT use the tight tolerance bolts for a test fit...
Bob
Aerospace Engineer '88
Structure - 90% Done
Cabin Top - Aaarrghhh...
Doors - Done
On Gear
290 HP Barrett Hung
Dues Paid 2017,...Thanks DR+
Old 01-04-2018, 10:04 AM
Hardware store bolts----get them longer than the actual bolts, cut off the threads and taper/round off the end.
Old 01-04-2018, 10:28 AM
mciaglia mciaglia is offline
Thanks. I have the 4 bolts in place now as I am building the fuse so those will be the ones for wing install. Thanks
Dr. Mark Ciaglia
Houston, TX
Donating Monthly since 10/17
N189PT- Christen Eagle II
N627DG (reserved)- RV10 in the making
www.marksfamilyrv10.wordpress.com
Old 01-08-2018, 03:01 PM
ppilotmike's Avatar
Default Another data point..
Originally Posted by mciaglia View Post
When fitting the wings for the first time...do you use the supplied precision bolts or something differennt, saving those for the final install
Mark,
I used the close tolerance bolts with the spacers in order to "align" the two center spar sections, while building my fuse. My thought was that I wanted them to be as closely aligned as possible, in the hopes that when I go to install the wings, the spar holes will all go together "like butter." The close tolerance bolts required patience and lubrication to work with, and it's possible I may have to buy new close tolerance bolts when the time comes for final assembly. However, I wanted everything to be as closely aligned during building as possible. I just didn't feel that "hardware" bolts would give me that. Your mileage may vary.
Mike Rettig
EAA Chapter 301, President www.eaa301.org
VAF Dues Current: as of 01/15/18
RV-10 (41PX Reserved) Fuselage
http://www.mykitlog.com/mikrettig
Old 01-08-2018, 03:03 PM
When you do the actual assembly with the close tolerance bolts, put them in a small ice chest with dry ice for an hour or so.
Helps......
Also, be sure the threads on the bolt/nut do not bottom out before the nut fully seats on the spar. As I recall, I had to install a thin washer on a couple bolts to get the stackup right.
Old 01-08-2018, 04:36 PM
Electrogunner Electrogunner is offline
Mark,
I did the same. Wondering if I need to buy new bolts now for final assembly? Thoughts anyone? May put a call into the mother ship as well.
Donation Made For 2017
RV10 N620RV
IO540 C4B5
Garmin 900x
Whirlwind 3 blade
Emmpenage 99.9999% done
Wings 99.99998% done
Fuselage SB 90.1% done. I think
Fuselage and tailcone is one.
Old 01-08-2018, 05:03 PM
Auburntsts's Avatar
Ditto. BTW, the plans recommend doing it this way. Less chance of screwing up some critical hardware/parts. Save the close tolerance bolts for final assembly.
Todd Stovall
PP ASEL-IA
RV-10 N728TT - Flying!
WAR EAGLE!
