Old 01-03-2018, 05:54 PM
togaflyer togaflyer is offline
Default Wings install question
When installing the wings, should the wingtips and flaps be on or off. Or does it matter. I plan to keep the ailerons attached since they are rigged.
Old 01-03-2018, 06:01 PM
Really should not matter-------I suggest you have them off, lighter and the tip rib makes a decent hand hold.
Have some hardware store bolts with the threads cut off to use a pins to help with getting things aligned. Round off the end a bit to make insertion easier.
I used a pair of saw horses to put the wing on and get basic alignment started, then picked up the wing and worked it into the slot------pretty easy after the first few times.
Old 01-03-2018, 06:02 PM
Carl Froehlich's Avatar
Flaps, ailerons and wingtips all off. Your helpers will be reaching for handholds and these get in the way - and are easily damaged.
Old 01-03-2018, 07:04 PM
Kyle Boatright Kyle Boatright is online now
Quite true.
Be sure to remind your helpers they cannot grab unsupported skin areas. EG, an area that extends beyond the aft spar...
Kyle Boatright
Atlanta, GA
2001 RV-6 N46KB
Old 01-03-2018, 08:53 PM
az_gila's Avatar
az_gila az_gila is online now
Question
How many times did you have to take them on and off?
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 01-03-2018, 10:42 PM
rleffler's Avatar
rleffler rleffler is offline
Twice.
Once everything as fitted, I took them off and stored them back in the wing stand. They were transported to and from my painterís hangar/shop in the stands. Once the aircraft was painted and back in the hangar, they were reassembled.
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
Old 01-04-2018, 06:45 AM
Thanks for the info...
Old 01-04-2018, 07:08 AM
az_gila's Avatar
Smile
Originally Posted by rleffler View Post
Twice.
Mike S implied it was quite a few times more.
I was wondering why.
Gil Alexander
Old 01-04-2018, 08:02 AM
Just simply to make it easier to walk around the plane. All wiring, aileron/flap installation and rigging was done at my home hangar, then the FAA changed the rules and I had to take the plane to a different airport to test fly. Luckily I had not yet installed the "real bolts", just used the test pins.
The wings on a 10 go on a lot easier than the earlier models, all bolts outside the fuse.
Old 01-04-2018, 08:33 AM
mciaglia mciaglia is offline
When fitting the wings for the first time...do you use the supplied precision bolts or something differennt, saving those for the final install
Dr. Mark Ciaglia
Houston, TX
Donating Monthly since 10/17
N189PT- Christen Eagle II
N627DG (reserved)- RV10 in the making
www.marksfamilyrv10.wordpress.com
