Old 12-30-2017, 10:59 AM
TomSpencer46 TomSpencer46 is offline
Default Wheel pants not translucent
Got time this weekend to work on my wheel pants. Plans call for drilling the holes for the attachment brackets by marking the brackets and seeing the marks through the translucent wheel pant. Vans must have changed manufacturing my pants are a dark grey opaque fiberglass. Vans is closed, anyone else solved this?
RV-10 started 11/15
1947 Bonanza 25 years flying
Home field (Spencer) VT09
Old 12-30-2017, 11:10 AM
The newer kits include small, spherical magnets, for hole locating.
Old 12-30-2017, 11:16 AM
Bob I will look, got my finish kit in July.
RV-10 started 11/15
Old 12-30-2017, 01:00 PM
arffguy arffguy is offline
Default Manual revision addresses the magnets
Look in the manual Section 5, page 5-18.
If you have an older manual you may not have the latest version of Section 5.
Go here:
http://vansaircraft.com/public/service-rv10.htm
Go to the bottom and look up Manual Section 5.
Mike F
RV-6A wings/fuselage
RV-3 empennage (extra thanks to Mr. Zilik)
RV-4 Plans only S/N 2938
Cessna 152
Elk Grove, CA
VAF #744 Exempt but paid in Feb anyway
Old 12-30-2017, 01:22 PM
rv7charlie rv7charlie is online now
The magnets sound faster, but shining a laser The cheap HF laser level works, but even a laser pointer would work for this) through each hole, then mounting the pant, will give you a dot at the right spot. Laser levels have a lot of other uses while building, as well.
Old 12-30-2017, 02:08 PM
thank you did not have this page.
RV-10 started 11/15
