Old 12-27-2017, 06:11 PM
asw20c asw20c is offline
Default Another &$$%^#^#@# Tool?
I'm at the step where it's time to dimple the outboard leading edge skins and just realized that there is no way my DRDT2 is going to be able to get to most of the rivet holes without completely undoing the prebent airfoil shape. How do you get in there to dimple? I'm guessing my tool-buying pause just came to a screeching halt? What did you guys use to dimple those holes?
Empennage Complete Except for Tips
Wings Underway
Old 12-27-2017, 06:20 PM
You can get there. It just requires brute force and bending your LE skins in ways that make you very uncomfortable. Just like you would have to do with a C-frame.
Surprisingly, the LE skins return to form, even after what seems like horrible abuse.
Kyle Boatright
Atlanta, GA
2001 RV-6 N46KB
Old 12-27-2017, 06:22 PM
Mel's Avatar
Mel Mel is offline
Pop-Rivet Dimpler!
A&P/EAA Tech Counselor/Flight Advisor
<rvmel(at)icloud.com>
North Texas (8TA5)
Legend Cub purchased 12/2017
FRIEND of the RV-1
Eagle's Nest Mentor
Old 12-27-2017, 06:24 PM
Tom023 Tom023 is offline
I used the DRDT2 to do mine, I must have because I have no other tool other than a pneumatic squeezer. It's been a while but I believe I put the skins outside up and drooped over the edge of the dimpling table. This allows you to basically bend it back easily to 90 degrees and so the handle can be pulled down without interference. The skins will rebound back to their original shape. If I can find a photo I will send it to you.
BTW I'm completing the finishing kit and engine arrives next week. I've never stopped buying tools and replacement parts!
RV14A #140083
Wings, empennage, fuselage and finish slow builds completed. Avionics Installed.
FWF in progress (temporarily on hold after unexpectedly having to move from T51 to KDWH)
2017 Donation
Old 12-27-2017, 06:56 PM
N941WR's Avatar
N941WR N941WR is offline
Originally Posted by Mel View Post
Pop-Rivet Dimpler!
Agree!
Oh, and you will never stop buying tools! Even after flying for 10 years, I find new tools I just simply must have!
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 12-27-2017, 07:52 PM
Pmerems's Avatar
Pmerems Pmerems is offline
Default Leading edge dimpling with a DRDT-2
This is a RV-7 tank skin.
Dream it, Build it, Fly it
Paul Merems (EAA Tech Counselor, EAA Sheetmetal Workshop Instructor/Volunteer 12 yrs)
ExperimentalAero-HANGAR BANNERS
www.experimentalaero.com
RV-7A (Flying since 2010)/RV-4 (sold 1990)
Tucson, Arizona 85749
Mudfly Mudfly is offline
Thumbs up Me Too!
What he said... I also turned the skins outside up and hung the inside edge under a table..if that makes since. Used the DRDT-2 with no problem.
Shawn Edwards
RV-14A (140174)
Empennage purchased (pre-owned) August 2015
www.myrv14build.blogspot.com
Old 12-27-2017, 10:52 PM
Default Make sure skin is flat
I did as the others with the DRDT2 also. But you gotta make sure the skin is flat, if the skin flexed on me, the dimple wasnt very good. It took me some force to keep everything lined up and flat on the most forward holes.
John S
Fuselage started
Old 12-28-2017, 07:29 AM
bkervaski's Avatar
Wait until you get to the avionics .. you pretty much need every crimping tool ever created in the history of mankind lol
Progress: Flying!
Old 12-28-2017, 03:51 PM
Thanks guys. I didn't think I could bend the skin enough to get access to the forward-most holes using my DRDT2 without causing a permanent set. Sure is helpful having folks who have already been there, and can show photos of how you did it. Thanks!
Wings Underway
