Old 12-18-2017, 05:34 PM
Eztroller Eztroller is offline
Default Countersunk too deep...
My question is replace the spar (HS 00903-1), or move on...? What surprised me was how fast the single flute countersinking cutter grabbed the material and took off!
https://photos.app.goo.gl/aKu9Nmvpmqo9D3Xr2
Old 12-18-2017, 05:51 PM
bkervaski's Avatar
Are you using a stop? There is a LOT of counter sinking, totally worth the $$
http://www.cleavelandtool.com/Thread.../#.WjhiuEtMGJY
Progress: Away for PAINT
Old 12-18-2017, 05:54 PM
TX7A TX7A is online now
Hey Brian
I don't know how thick the material is, but it may have a bearing on if it's too deep or not. I would certainly run it by Vans & see what they have to say.
Also, be sure to make a couple of test runs on some scrap with the countersink cage before you do the part. It may save you some grief.
Good luck
Sam
Sam Evans
RV7-A O-360 C/S
VAF#812
Old 12-18-2017, 06:06 PM
yes, I was using a cage but obviously screwed something up.... I have an email into VANS. I cant quite tell from reading ahead why the instructions call for countersinking here (page 8-2, step 5), but hopefully it wasn't a $75 mistake! Thanks for the replies.
Old 12-18-2017, 06:15 PM
wirejock's Avatar
wirejock wirejock is offline
Default Countersink
Definately too deep for a rivet but often deep is relative to the part nesting in the countersink and location. Refer to Vans Mil-spec document for countersink dimensions and hopefully they will have good news for you tomorrow.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
Old 12-18-2017, 06:38 PM
Saber25's Avatar
Saber25 Saber25 is offline
Buy a new part and get a fresh start. Use the spar for test holes from now on before you start countersinking other critical areas. I always did a test on a spare piece to make sure the size and depth was correct before proceeding. Countersinking and dimpling are a fundamental skill in assembling an aluminum airframe and you'll have piece of mind when done correctly.
Cheers, Hans
Build 'em light, keep it simple
I'd rather fly than tinker.
"There's a big difference between a pilot and an aviator. One is a technician, the other is an artist in love with flight."
- Elrey B. Jeppesen,
Old 12-18-2017, 08:08 PM
Tom023 Tom023 is offline
Front and rear HS spars are $46 each. Shipping for one or both is $130 to Texas hopefully you can just go pick up.
RV14A #140083
Wings, empennage, fuselage and finish slow builds completed. Avionics and engine installed.
Down to last 90%.
2017 Donation
Old 12-18-2017, 08:40 PM
Thanks for all of the feedback. I checked the mil-spec and it is definately too big.
Tom,
Thankfully its a 20 minute drive to Vans. Will wait to hear fron Vans, but expecting an early afternoon trip tomorrow.
Old 12-18-2017, 09:44 PM
Aluminum Aluminum is offline
You may be able to go to next size up rivet. Check with mothership.
Dan V
'91 Zodiac flying since 2013
RV-14A in progress
2018 dues worth every penny
Old 12-19-2017, 07:40 AM
NavyS3BNFO NavyS3BNFO is offline
Default Definitely too deep
I made the same mistake on my flap spars. After I made the mistake I found Section 5.5 where Van's recommends 7 'clicks' past flush when countersinking to accept a skin dimple. That corresponds to .007 past flush which is barely perceptible and a lot less than you think you need but it works.
I used my caliper to measure a test piece to set my csink cage then csunk the flap spars. Until I got comfortable I think I measured everyone. Then I measured every 5th one or so.
Proper depth
Picture of one too deep
RV-8 empennage DONE
Wings in progress
