Old 12-19-2017, 09:28 AM
Steve E Steve E is offline
Default In luck, I can help!
I have just what you are looking for: RV14 N814SE located at KCHD. I would be happy to show it to you, although you should know that I am not the builder so I will not be able to answer lots of your questions.
Steve Eddy
email: seddy2@cox.net
cell: 480 282-7604
Old 12-19-2017, 09:47 AM
I flew a Lyc IO-360 powered Swift for close to 200 hours, learned acro in it, and spent a lot of time in non-straight&level mode. No inverted oil system, and no flop tube.
I never did any sustained negative G stuff in it, but lots of Cuban 8's, loops, rolls, point rolls, barrel rolls, hammerheads, etc. Never once had the engine sputter (except in level flight when running a tank dry before switching).
Never a noticeable loss of oil pressure, either.
If you want to do real negative G stuff, be safe and buy/build a Pitts. (Loops and rolls aren't negative G maneuvers; contrary to somewhat common opinions.) :-)
Charlie
Old 12-19-2017, 10:11 AM
iamtheari iamtheari is offline
My only real questions are "How do I fit into the plane?" and "Is it awesome or super-awesome?" I'm going to be taking lessons at Chandler, two a day morning and afternoon, the 26th through 30th. Private message to follow with contact info so we can try to coordinate. Thanks for responding!
Old 12-19-2017, 10:12 AM
Charlie
Great, now I have to build TWO airplanes. Here I am, trying to talk myself out of building one, and you come along with the Pitts suggestion.
Old 12-19-2017, 11:32 AM
ChiefPilot's Avatar
ChiefPilot ChiefPilot is offline
With inverted systems, negative G stuff is perfectly safe in an aerobatic RV, same as positive G stuff.
Brad Benson, Maplewood MN.
RV-6A N164BL, Flying since Nov 2012!
If you're not making mistakes, you're probably not making anything
Old 12-19-2017, 12:32 PM
Berchmans Berchmans is offline
Default Inverted
I fly aerobatics in my RV8 and do not spend a lot of time at negative G. I originally build the aircraft without an inverted oil system. I did learn however that seconds at negative G can lead to hours scrubbing oil off the belly. I got tired of that and put the complete Raven inverted system in. You could go the half Raven system but I just bit the bullet. I hate laying on the creeper with a rag.
Burke Wick
Flying RV 8
Anchorage, Alaska
VAF Dues Paid for 2018
