Old 12-12-2017, 02:59 PM
bkervaski's Avatar
Default Aft Left Baffle .. how?
How did you guys attach your aft left engine baffle? I can't find an angle of attack to get it installed.
Progress: First Flight Prep
Old 12-12-2017, 03:02 PM
Super Moderator
Few choice words, some magic dust, etc. It is a wrestling match. Don't hesitate to use some brute strength.
Vic Syracuse
Van's East Coast Representative
www.Baselegaviation.com
Old 12-12-2017, 03:08 PM
bkervaski's Avatar
Thanks, Vic. I'm a bit worried about scratching that pretty red paint
Old 12-12-2017, 03:10 PM
coffeeguy coffeeguy is offline
Vic's comments reminded me of the old adage, "don't force it, get a bigger hammer".
Jeff Dingbaum
RV-14A empennage, wings
Cherokee 180
2017 dues paid
Old 12-12-2017, 03:25 PM
Nova RV Nova RV is offline
The only baffle that I needed to trim a little to fit was the forward left one. The aft left gets hung up on something then pops into place. Make sure also it's in place around the valve cover (pretty chrome) as that sets the proper angle for seating the back.
Chris Moon
Leesburg, VA
RV-14A kit # 140243
VAF 2017 and 2018 paid
www.mykitlog.com/chrismoon/
Old 12-12-2017, 03:32 PM
bkervaski's Avatar
Just went and tried 100 new different ways to try to install it .. I must be missing something obvious lol .. time to take a break and come back to it later please keep the suggestions coming though
Old 12-12-2017, 07:03 PM
crabandy crabandy is offline
Hard to describe but......start the baffling piece at a 45* angle both horizontally and vertically from how the rear baffle will sit on the the engine (slide the baffling in from the top of the engine). Make sure the corresponding lower portion of the baffling fits over the barrel (not the larger head portion) and slightly twist and lower into position. Seems the barrel to head transition of the baffling was the main culprit of the piece not fitting.
RV 7 300 hours and counting
12/17 donation
Old 12-12-2017, 07:23 PM
sjhurlbut sjhurlbut is offline
Default Screws
I recommend attaching the pieces together with structural screws or bolts. It will make you swear every time it needs to be removed.
"Aerodynamics is for people who can't build engines"
Enzo Ferrari
Steve H
Cold Lake, Alberta
RV7A #70015 - C-FZQX - built - sold
RV7A #71629 - C-FSIS - built - sold across Atlantic
RV7 #70215 - C-GOJU - flying - sold
RV7 #70703 - C-GMIY - flying - sold
RV6 #60119 - C-FHBZ - built - Airventure 2016 Bronze Lindy - sold
RV10 #41779 - built emp - sold
RV8 #82842 - C-FSBG - Fastback with big hp IO-360-A1B6 10:1
Old 12-12-2017, 08:50 PM
bkervaski's Avatar
My issue exactly. Did you have to trim anything?
Old 12-12-2017, 11:34 PM
I trimmed most pieces, but it's been too long to remember exactly what. I've removed that piece multiple times since though, and the above paraphrasing is my best at describing it. As I recall you can't be too shy about it, mine wasn't painted but I don't think I could install it without a scratch.
12/17 donation
