Old 12-28-2017, 08:10 PM
Default Door Hinge Priming/Cad Plating, Etc?
I look at the door hinges and can imagine paint/primer being abraded off as the edges of the hinges scrape against one another every cycle. If that's the case, rusty hinges could be a long term issue.
That said, has anyone had their hinges Cad plated as a second line of defense against corrosion (the first line being paint/primer)? If so, who did it and what did it cost?
Are there other alternatives I'm not considering?
Kyle Boatright
Atlanta, GA
2001 RV-6 N46KB
Old 12-29-2017, 05:23 AM
rleffler's Avatar
rleffler rleffler is offline
Mine are painted and look just fine after 4.5 years of flying.
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
Old 12-29-2017, 05:55 AM
Jesse's Avatar
Jesse Jesse is offline
We have ours chromed and that holds up really well. Powder coat is another good option.
Jesse Saint (Saint Aviation, Inc. - VAF Advertiser)
352-427-0285
jesse@saintaviation.com
RV Hotel (hangar, room, car) at X35 in north FL
Commercial ASEL/S A&P/IA EAA Technical Counselor
Dynamic Prop Balancing, Prebuy Inspections, Condition Inspections, Repairs and Mods, Injector Tuning, Airframe, Engine, Panel Upgrades, Ferrying, etc.
Old 12-29-2017, 07:22 AM
9GT's Avatar
9GT 9GT is offline
I seem to recall going back maybe 5 or 6 years when I was building my 10 that there was someone, or some company, here on the forum that manufactured and sold stainless steel door hinges for the RV-10. They were VERY pricey though. I treated my hinges and pins with OTC steel blueing, which adds a little bit of protection, then primed and painted (not the pin) before final installation. The hinge side recess on the cabin cover was then filled with micro, then a couple layers of glass overlay and feathered in. Every so often a squirt of oil on the exposed parts and pins to help lube and protect the exposed surfaces.
David C.
Howell, MI
"Donor Exempt" but donated through Dec. 2018
Old 01-12-2018, 05:02 AM
Maddawg99 Maddawg99 is offline
Just a thought: Take a look at Cera Kote. You bake this on at 250 degrees and
it forms a tough, thin barrier. Mostly used on firearms, but may work well here..
Maddawg
