Old 01-23-2020, 10:23 PM
lr172 lr172 is online now
Originally Posted by rwtalbot View Post
I am making an assumption here that the Slick bearings generally run to TBO without failure.
Not a good assumption. Slicks requires a 500 hour inspection; That is their TBO, though the requirement is IRAN and not overhaul. Even the manufacturer doesn't trust them past 500 hours. I don't think that bearings are a common failure at 500 hours, but that is their recommendation. Slick mags are very far from the most robust component on a lycoming engine. It is not the standard that I would follow when designing a part.
N64LR
RV-10 in Phase I
Old 01-23-2020, 10:55 PM
rwtalbot rwtalbot is offline
Originally Posted by lr172 View Post
Does slick use and interference fit on the shaft AND the bearing housing bore? My point was not the amount of interference, but that the bearing ID should be interference and the OD slip.
My intent was not to question your effort here, only to point out what I learned from engineers that do bearing application engineering for a living.
Hey Larry, No offense taken or implied. There are lots of people on here with a low more knowledge and practical experience then I have. That's why I asked.
In the Slick both inner and outer races are an interference fit, which seems to odd, given the need for internal clearances. That is why I asked what you and Dan had done
I agree mags are not the most reliable items on an aircraft, my point was that they have quite a few hours in the field.
Richard Talbot
RV-7A
Sydney, Australia
Old 01-23-2020, 11:23 PM
I suspect Slick had a reason for doing it. However, it goes against industry convention and I would exercise caution following their lead, unless you know why they did it.
FYI, mine has been in service for over 500 hours without a hiccup. The design is similar to the version dan posted. It will be interesting to see what Dan did on his bearings. I am sure his has as many or more hours on it.
Best of luck on the project. FYI, I built two of them and only used one. Happy to sell the extra if you get frustrated.
N64LR
RV-10 in Phase I
Old Yesterday, 10:52 AM
WingsOnWheels WingsOnWheels is offline
I found a source for the EDIS pins. Just ordered 15 for $8 shipped. Let me know if you are in need.
If you buy a used module, get one with the connector, they are easy to un pin and reuse the connector body.
Colin P.
RV-6A #20603
Complete 5/10/19
PP SEL / A&P
I donate every year on my B-Day (in Dec), but donated early in Sep'19.
Old Today, 12:51 AM
Hey Colin, that would be handy. We need enough to do at least 6-8 units over here.
Richard Talbot
RV-7A
Sydney, Australia
