C-1447 D seal material
iamtheari
Page 38-34 steps 12-15 relate to the C-1447 D seal. It appears that this is the SEAL-00005 material. However, this is not explicitly stated anywhere that I see in the plans. I want to be sure I use the right stuff.
It's the white seal ... if you need more you can also get this at the Home Depot on the Aviation isle.
The piece in the kit is enough to build two canopies. Unfortunately it?s the blockier seal material that I ran out of due to mistakes. I?ll be in a bigger town with aviation stores like Lowe?s this weekend so I can try to find replacement.
