G3X Touch: Monitoring 3 AMP sources
supik
I would like to monitor 3 amp sources:
-alternator 1 (hall effect sensor)
-alternator 2 (hall effect sensor)
-battery bus (shunt: provided with the G3X kit)
Can I display / monitor all 3 ampmeters on the G3X's electrical page at the same time?
The GEA24, at least on my configuration page, has two inputs to monitor voltage and 2 inputs for shunts. Not sure if there is a way to get a 3rd.
Hello Igor,
The system has 2 dedicated shunt inputs, and multiple general purpose inputs which can support hall effect current sensors, so you should be able to use 3 current sensors if you think that is necessary.
Steve
Thank you!
That?s what I read in the manual, but is the system able to display all 3 current sources on 1 page?
