Old 10-10-2017, 08:39 AM
Raymo's Avatar
Raymo Raymo is offline
Default Which VSWR Meter?
I want something to help troubleshoot poor radio transmission issues and found one thread that recommended the MFJ-812B but it is not designed for the VHF frequency range in our radios (108-136MHz).
I'm looking at the MFJ-874 and it is designed for HF/VHF/UHF but quite a bit more expensive than the one Gil recommended.
Any other recommendations from the fleet?
Ray
O-360-A4M w/ Catto 3 blade NLE, AFP FM-150 FI, 1 PMag, Vetterman Trombone Exh, SkyTech starter,
PlanePower Alt, FlightLines Interior, James cowl & plenum
All lines by TSFlightLines
NSDQ
Old 10-10-2017, 08:55 AM
DaleB's Avatar
DaleB DaleB is offline
MFJ-844, or one of the many similar and less expensive models... like this one. If it's designed for VHF, it will probably be fine at airband frequencies. If you want to get really fancy, the MFJ-259 can tell you whatever you want to know about your antenna and coax.
Dale
Omaha, NE
Previous RV-7 project (sold)
-=VAF=- 2017 dues paid
Old 10-10-2017, 09:08 AM
RV6_flyer's Avatar
Default MJF-259
I have used the MJF-259. It is more expensive but will do just about everything I want in both aviation and amateur radio.
Gary A. Sobek
NC25 RV-6
Flying
3,300+ hours
Where is N157GS
Building RV-8 S/N: 80012
Raymo's Avatar
Thanks, Dale. I see the 844 specified frequency ranges 140-150, 430-450MHz
Will this also work in the 108-136 range? The 259 is very nice but more than I'd like to spend at the moment (~$100).
Ray
NSDQ
Old 10-10-2017, 09:37 AM
N804RV's Avatar
N804RV N804RV is offline
I use a Workman Model 104 with a couple of BNC male to PL259 adapters. Cheap and works great.
If you're not experienced with coax connectors, or don't want to buy the tools to make nice "low-loss" connectors on RG-400, Aircraft Spruce will sell you custom made coax for your radios. Definitely worth the price!
Ken W.
Mount Vernon, WA
2018 VAF Supporter
Old 10-10-2017, 09:40 AM
DaleB's Avatar
I'd be very, very surprised if it didn't.
Dale
Omaha, NE
Old 10-10-2017, 09:51 AM
az_gila's Avatar
az_gila az_gila is online now
Smile Good old thread
Amazing a link in one of my threads from 10 years ago to a product that still exists and is still $39.
http://www.mfjenterprises.com/Produc...uctid=MFJ-812B
The unit I linked to is marketed for the 144 and 22 MHz bands, but the data sheet says it will work down to 21 MHz with reduced sensitivity.
It will have no problem at our aircraft frequencies that are around 120 MHz.
It also appears the front panel marking has changed a bit and is now labelled 114-220 MHz, definitely suitable for aircraft antennae.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 10-10-2017, 10:36 AM
Raymo's Avatar
Thanks all. I plan to try a few of these low cost units until I can splurge for a Rig Expert Antenna Analyzer, which are pricey but fantastic units.
Ray
NSDQ
Old 10-10-2017, 11:09 AM
Aluminum Aluminum is offline
If you are skilled at soldering you can build a clone VNA for not much money:
http://www.ebay.com/itm/PCB-for-buil...kAAOSwcLxYFNvQ
Dan V
'91 Zodiac flying since 2013
RV-14A in progress
2018 dues worth every penny
Old 10-10-2017, 11:53 AM
fl-mike's Avatar
fl-mike fl-mike is offline
You can borrow my bird. Send address
Mike W
Venice, FL
RV-6A. Mattituck TMX O-360, FP, GRT Sport EFIS
N164WM
N184WM reserved (RV-8)....tail kit done, slow-build wing done, slow-build fuselage started.
