It's easy to set up; the problem with light aircraft is getting he two antennas far enough apart so that one transmitter doesn't overload the other receiver. At a minimum try one antenna on top, the other on bottom.
You can either wire the radios thru appropriate switches, or some audio panels (e.g., PS engineering's 8000 series) have this function built in.
Its a one button push to select from comm1 to comm2 on most intercom panels. I am not sure what the advantage would be to set it up as you describe unless I am missing something.
George
We use it all the time in the rv10. One antenna on top other on bottom, no interference. We have the PM8000. Works well for PIREPS etc
Guys: I have a Garmin -340 intercom and it has the ability to use two radios at the same time. I have exercised this function often in our SAR activities. Additionally, I have both antennae on the bottom of my -9A about 24" apart laterally. The antennae are Commant and the radios are GNC 300XL and SL-40. Dan
Dan and Galin, I have a 340 also, and the only way I know how to use two radios simultaneously is via the split comm function?which works the same way the others have described the same mode in the PM8000B (pilot on comm 1, co-pilot on comm 2). In that mode, each seat cannot hear what the other seat is saying or hearing (AFAIK).
I think Brad wants to be able to listen to both radios full time, and transmit on one or the other as needed?without reaching up and switching the audio panel.
Example would be listening/talking to ATC while leading a formation. One way to do this would be to have the mic key for each radio wired to a different button on the stick grip. However, on the 340, you can listen to any audio input simultaneously, but only one mic button can be selected at a time, unless you go to split mode?which isolates the two. Perhaps you could wire the second button on the stick as if it was the copilot button, but I'm not sure how to wire it to be able to listen to the second radio in split mode. A friend has his HRII at Mutha's (I mean Badger's ) place for a new panel, and he wants exactly this capability. Maybe Jon has the gouge on how to do this. I'd be very interested in the how to as well!
Bob
Bob
Can one seat talk on 1 & 2? Or does it have to be one seat on 1, one seat on the other?
